HI Conrad, you are right, the plates are INVAR and don't show wisker.
The the housing (can) and the mounting base are tin plated and are prone to wisker. We had short cuts to the feedthrough and we found wisker parts flying around in the can..
I regulary check my caps isolation resistances.. and I had wiskers (one plate some kOhm to housing) even with genuine GR 1404s , applied a 400V pulse to burn the free.. got luck the value didn't change (recal rigth after)
The INVAR plates look horrible ... OK, due to my rough torch desoldering they migth get smoked a little
but surface and edges of the genuine GR part look better.
however we want to give it a try and polish (and gold plate) them ..
Two units are open .. I bet after remouting , N refill , and tempering (this time without a torch
) it will cost me one unit for our Cap-lab people
And I need a way to get rid of the tin plating.....
