So I considered a simple structure, such as leaf spring RF gasket strip. The shape is somewhat simple, the idea is you get a small flat line of contact with a plate when you screw the thing together.
As far as materials go, you can typically get sheet metal something like
1) full soft
2) half hard (or fractions hard)
3) full hard
4) spring temper (is this different then full hard?)
Now, lets say you get the spring temper metal sheet. And you cut into it, so you have a shape that can be bent into a contact.
Do you just form it to get the right shape with the starting temper that you have, or do you have to do additional work hardening steps to get the contract functional? I.e. it would be considered a useless bend step, because you can theoretically get the correct shape through less amounts of bends. Kind of like if you are making something from a paper clip, you might want to bend it back and forth a few times before you shape it to get it toughened up.
I would assume they just focus on shaping it, and not 'working' the material during the forming process??? i.e. least amount of steps required to get the correct shape.
With a spring, you only form it to shape and possibly heat treat it afterwards. I never saw anyone doing anything 'funny' with spring manufacture. Are contacts the same?
And, for plating, do they consider the surface strain effects of certain plating to be part of the springs behavior? i.e. that you have to plate after you bend, for spring reasons? (because I only would consider plating after bending if It has something to do with crack formation reduction, rather then considering the plating to be 'finishing' the behaviors related to the 'spring constant" of the structure.... possibly having to do something like choosing a plating process that is high strain to 'adjust' the spring. Again, to me it seems like this would NOT be what they do.
And I mean for a real contact, where you spec out the starting material, not super mcguyver repairs with improper starting materials.
