Author Topic: Precision Grooving tool  (Read 4196 times)
Offline xzswq21Topic starter
« on: November 03, 2021, 11:46:16 am »
Hello
The cross section of turning tools is 8x8: (unfortunately in our country I couldn't find 8x8 turning toolset, they only have 16x16 and 20x20 tools)
For the turning tools I have chosen a 8x8 toolset from WABECO:
https://www.wabeco-remscheid.de/catalog/category/view/s/drehstahl-satze/id/638/?product_list_limit=32
but I have a problem. as you see in the below picture I need a precision grooving tool to make such slots with a 1.5mm width, 0.7mm depth and 0.02mm Accuracy.
I found a precision grooving tool at page 3 (from Graf-Werkzeugsysteme in Germany):
https://www.phorn.co.uk/fileadmin/user_upload/media/PDF/2015_Catalogue_Sub-Sections_EN/Carbide_Grooving_Tools_Chapters/S274.pdf
but I couldn't contact the company because they only accept a company email.
Does anyone know such a precision grooving tool?
Thanks
Offline Carel
Re: Precision Grooving tool
« Reply #1 on: November 03, 2021, 03:09:22 pm »
Just buy the 8*8 10 euro parting tool in the link and go grinding. That's life in turning.
For a 1.5 mm "precision groove" you need a tool of 1.3-1.4 mm width. Dig in and finish left and rigth.
The precision is not in the tool, it is in the operator.
https://www.wabeco-remscheid.de/rund-ums-drehen/abstechstahl-halter.html
The following users thanked this post: xzswq21
« Reply #2 on: November 03, 2021, 05:01:01 pm »
For a 1.5 mm "precision groove" you need a tool of 1.3-1.4 mm width. Dig in and finish left and right.
:)  I didn't show you the complete design. The groove is very accurate. When you want to produce thousand of things and another country must evaluate the accuracy and the quality, it's better to use a reliable tool.
Offline mc172
« Reply #3 on: November 03, 2021, 05:21:14 pm »
You don't specify whether it's +/- 0.02 mm or 0.02 mm in total, so I will assume the former as it's the most generous case.
The tolerance of those Horn inserts is +/- 0.02 mm which is your entire tolerance budget. There is an additional +/- 0.015 mm indexing tolerance. The datasheet doesn't specify which axes this affects, just "indexability length". There is also no tolerance on the position of the grooving width relative to the reference plane, which could be this "indexability length" they're on about.
So clearly relying on the tool geometry to achieve tolerance is not the way to go.
That said, Horn tools are good quality and I like them. I've bought used holders from eBay before and bought new inserts from local tooling places.
The following users thanked this post: Kean, xzswq21
Online Benta
« Reply #4 on: November 03, 2021, 05:58:46 pm »
What Carel said. You use a narrower tool and go in zigzag-wise.
Offline Carel
« Reply #5 on: November 03, 2021, 06:41:40 pm »
You should'nt play hide and seek. One does'nt need the design to advise on a tool. "Very accurate" makes me doubt that very design, it is a flexible term. If you want to outsource, you have to come up with shop language.
If you yourself can't decide on the quality and of course the proof of concept, but depend on another country for quality raises other questions. Start near, go far. Start far, fall near.
Offline Smokey
  • Not An Expert
« Reply #6 on: February 07, 2022, 06:30:49 am »
For the highest in precision... Here is the link to generic Chinese ebay 1.5mm grooving tool!
1.5mm Carbide Insert MGMN150-G + MGEHR1010-1.5 groove cutt-off Lathe Tool holder
https://www.ebay.com/itm/165161178616
This thing actually does a decent job in my decidedly un-precision garage shop.
