Odd question, but feel this falls under "automation", however, it also applies to anyone with an irrigation system.
I have PGP (the company name) MP rotators for my irrigation system. Last year I had one of them swapped for a larger size, so I have this one as a spare/junk one.
In order to adjust the turning amount (mine are 90 degrees to 270), a special tool is required, but appears to be nothing more than pushing down on the silver part and turning it. The "radius" (the distance it throws the water) is adjusted by a small screw on top.
Yesterday I began wondering how these little things work, so I attempted to dismantle my spare/junk one but can't figure out how to dismantle it (I turned the tiny screw on top several turns but it didn't seem to loosen anything). Also, from what I see, I can't figure out how these adjustments change anything.
I assume the screw turns some valve internally which changes the amount of water, but I can't figure out how turning the silver dial changes the rotation.
Has anyone dismantled one to see how they work or understand how they work?
