Just for completeness sake Epic model is now complete.
https://a360.co/2XZg1u0Some of the details
17 Discrete Externally created custom models linked into the design (some of them then used multiple times) plus about 6 small Models created in the larger model.
Maybe 20-30 externally sourced models/components from various libraries are used within the various models.
Something over 150 Sketches
Having a quick look at some of the sections and there is well over 1000 bodies in the overall model.
Ryzen 3700X 32GB and a 5700XT Cruises fairly much. The GPU numbers peak around 40% if you really spin the model around, memory usage is fairly light peaking at about 8Gb. That all changes when you try an in-canvas (local) render all cores pegged and very light GPU load
![Evil >:D](https://www.eevblog.com/forum/Smileys/default/evil.gif)
The online viewer also has some good features you can right click on bits and hide them or also add markups and export views.
