So I want to polish up some male banana contacts that are chassis mount on some stuff and I thought a good way to go would be green rouge on a loose buff on a dremel wheel. By loose buff I mean you can have solid wool buffs, stitched buffs, and loose buffs, the loose one looking kind of like a dainty flapwheel.
I have trouble getting solid compound on these buffs. With a stiched, sisal or wool buff, you press it in hard enough and it gets an appreciable amount of compound on it, but the loose buff just slaps along the surface.
Is there a trick to this? I have only been using liquid compounds (i.e. brasso, chrome polish, etc) on these buffs because its easy to apply. Are my compounds just too tough? are these for liquid only?
https://cmpstone.com.au/product/loose-leaf-calico-buff/You can have stitched, semi stitched or totally loose, I am using the ones that are minimally stitched.
