If anyone else gets to owning one of these or a similar one start adjusting the mirrors and lenses with either a bottle of Scotch or a bucket of Coffees at the ready. The main reason I have noticed a possible issue was on the deeper Acrylic cuts that were not even on all sides.
So a Rainy miserable day and after watching a heap of videos on the subject thought I would tackle seeing how far out of Tram and Trim the axis, mirrors and lens were.
How I tackle this sort of job on any of my Printers or my baby CNC router in the past is check for square mechanically adjust then tweak, tweaking first with a machine not squared is doomed to failure. Due to length considerations it isn't practicable to fit a low power laser pointer in the path so 5% power from the main laser with all the covers off but with the
![Cool 8)](https://www.eevblog.com/forum/Smileys/default/cool.gif)
fitted firmly on the face for the afternoon!
The Y axis mirror assembly was set nearly 3mm high on a mirror of about 16mm in diameter and the laser spot is getting close to the sides.
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
and the final mirror and lense holder was set about 2mm to far away from the X axis. While the Laser works fine as is getting everything more square mechanically makes setting the optics easier. with the trim screws on the mirrors. Both the intermediate Mirror and Lense holder and mirror were a few degrees skewed from the frame as well.
With everything mechanically now as close as possible time to breakout the masking tape to 'correct' the now incorrect mirrors that were covering up the misalignment to a degree. So it seemed like 1/2 a roll of masking tape later and everything is now fairly close and time for a final
![Tweak :-/O](https://www.eevblog.com/forum/Smileys/default/smiliey_cal.gif)
The SVG Target file is in a zip for anyone it might help and suits 16mm apertures. These are what I am now using instead of the tape which tends to catch fire
![Shocked :o](https://www.eevblog.com/forum/Smileys/default/shocked.gif)
