Question: how should I interpret the "board area" in the specs of the machines?
E.g. the HW-T4-50F has 350x190mm. What if I have chips that come in trays? Does the space of the tray take away from the max. board size or is it mounted somewhere outside of the board area like the feeders?
Also, if I don't use all feeder positions, would I be able to make a custom pickup position for a single chip, mount it instead of feeders, have the machine pick up the chip from there and manually re-fill it after every board?
