Author Topic: HWGC P&P machines - Documentation, Discussion and Info  (Read 117800 times)
Offline stefangem
    • cnc-technics.de
Re: HWGC P&P machines - Documentation, Discussion and Info
« Reply #350 on: May 25, 2024, 01:41:48 pm »
Hello,
can you me help to create a PCB Array. in the manual is this false. I have the smt550.
i will make 2 PCB in X (next to each other). in the software comes always "cannot Edit" when i will GEN PCB.
what are the instructions?
first from the first pcb to a fiducial and than the second pcb to the same fiducial?and than generate?
this has no function. always "cannot edit"
when i make on the plate a IC is this not a problem. but the fuction to make a pcb array is very difficult.
Regards
Stefan
« Last Edit: May 25, 2024, 02:27:42 pm by stefangem »
The following users thanked this post: liuhwgcsmt
Offline JacksterTopic starter
    • PCBA.UK
« Reply #351 on: May 26, 2024, 12:10:22 pm »
Hello,
Regards
Stefan
You have to do it during the setup steps after setting the Mark fedicuals.
Offline 48X24X48X
  • Country: my
    • Rocket Scream
« Reply #352 on: May 26, 2024, 12:11:57 pm »
Hello,
Regards
Stefan
I think I have this panel instruction in my videos. Check them out.
Offline stefangem
    • cnc-technics.de
« Reply #353 on: May 30, 2024, 10:37:01 am »
I have done.
you have to mark the fiducial first and go to PCB Array, then the first and the last PCB mark from th fiducials.
Offline Yuriy.m
  • Country: by
« Reply #354 on: August 02, 2024, 07:02:58 am »
Good afternoon, colleagues! the SSD died on the t63. changed, everything was set up. The smd test is taking place. but all positions are in error. Who knows where to dig?
Offline Yuriy.m
  • Country: by
« Reply #355 on: August 02, 2024, 07:05:03 am »
foto
    • PCBA.UK
« Reply #356 on: August 02, 2024, 09:01:44 am »
Did you make a backup of your original one or the SMTprog folder in the C drive when you got the machine?
Offline Yuriy.m
  • Country: by
« Reply #357 on: August 07, 2024, 11:29:47 am »
it was some kind of glitch... I recreated the project and everything worked. I have a couple of questions, what is the latest software for today? and how do I change the placement of the basket?
Offline Yuriy.m
  • Country: by
« Reply #358 on: August 08, 2024, 03:56:31 pm »
I have the T80 and T64 models. In the T64 model, the design of the 5.6 nozzle has been changed. now you can install large components. but you also need to move the trash to another location. How do I set this up?
« Last Edit: August 08, 2024, 04:08:50 pm by Yuriy.m »
    • PCBA.UK
« Reply #359 on: August 08, 2024, 04:24:55 pm »
Calibration menu. Bin location
Offline pastaclub
  • Country: th
« Reply #360 on: August 11, 2024, 09:08:34 pm »
Question: how should I interpret the "board area" in the specs of the machines?
E.g. the HW-T4-50F has 350x190mm. What if I have chips that come in trays? Does the space of the tray take away from the max. board size or is it mounted somewhere outside of the board area like the feeders?
Also, if I don't use all feeder positions, would I be able to make a custom pickup position for a single chip, mount it instead of feeders, have the machine pick up the chip from there and manually re-fill it after every board?
Offline 48X24X48X
  • Country: my
    • Rocket Scream
« Reply #361 on: August 12, 2024, 12:23:50 am »
Yes it does, trays will make your maximum rail width smaller. You can use the tray function to put in chips even in single quantity. Easy way is to 3D print smaller tray that hold various chip sizes that you don't have in tape form.
Offline pastaclub
  • Country: th
« Reply #362 on: August 12, 2024, 02:46:30 pm »
Thank you! In case of using a tray, which dimension gets shorter? The long or the short one? Or can it be any?
Offline Yuriy.m
  • Country: by
« Reply #363 on: August 14, 2024, 11:05:22 am »
I came from a business trip. I changed the position of the trash can. everything is working fine now. I can put both small components and large ones . the revision turned out to be excellent, I have already made more than 1000 boards. PS what is the latest version of the software?
Offline pastaclub
  • Country: th
« Reply #364 on: August 20, 2024, 01:29:26 pm »
Can these machines be seperated into two parts (upper and lower) to move them through a door? On the photos there is a horizontal line underneath the feeders. It looks like this is where a "foot" connects to the main machine. Is that the case or am I mistaken?
I am interested in the T64F / SMT660 model, but I'd have to move it through a 86cm wide door and I'm not sure if that's possible.
    • PCBA.UK
« Reply #365 on: August 20, 2024, 01:34:53 pm »
A few people have done this.
Not that much holding the two parts together but you won't want to touch the XY gantry. You only have a few cm from the top of the head.
Feet and wheels can come off to save about 8cm.
Offline 4Project
  • Country: il
    • www.4project.co.il
« Reply #366 on: September 25, 2024, 05:47:35 am »
Did you have the T6 machine arrive with the high nozzles by default?
Or you asked them to replace the nozzles?
Offline Yuriy.m
  • Country: by
« Reply #367 on: October 15, 2024, 11:24:57 am »
No. I redid the last two nozzles myself. now I can take high components. but they should be placed last in the list and in a certain order.
can you tell me which electric feeder is suitable for our machines? 8mm desk number ? suppliers?
    • PCBA.UK
« Reply #368 on: October 15, 2024, 11:33:41 am »
Contact Liu at HWGC. He sells feeders at a great price and the quality if really good.
Make sure to ask for black top electrics.
Offline liuhwgcsmt
  • Country: cn
  • HWGCSMT. Liu
« Reply #369 on: October 16, 2024, 11:51:32 am »
Hi dear stenfan, i have the video of how to creat the pcb array for you, can add my whatsup:  86-15931673319
And you can also see our Channel for the operation video of PCB ARRAY:
One stop solution for SMT Machine
WhatsApp:86-15931673319
HWGC SMT Manufacturer directly supply
Offline liuhwgcsmt
  • Country: cn
  • HWGCSMT. Liu
« Reply #370 on: October 16, 2024, 11:57:30 am »
hi dear,
Thanks for you all information, but this is not our factory sale, this is from resales, and also the model you have show in this page are really old page,
we have HW-T4-44F(DESKTOP)  HW-T4-44F(VERTICAL)  HW-T4-50F(DESKTOP) HW-T4-50F(VERTICAL) HW-T6-64F/  HW-T8-72F/  HW-T8-80F, HW-DU400-64F/  HW-DU800-92F/  HW-M8-102F
If need more information can contact our facotry directly .
wahtsup: 86-15931673319
E-mail: sjzwglw@163.com
Offline liuhwgcsmt
  • Country: cn
  • HWGCSMT. Liu
« Reply #371 on: October 16, 2024, 12:06:54 pm »
Hi dear all,
I am Liu, sorry for late reply, if need any technical support please contact whatsup: 86-15931673319   E-mail: sjzwglw@163.com
for purchase also can contact me
Thanks
Liu
Offline liuhwgcsmt
  • Country: cn
  • HWGCSMT. Liu
« Reply #372 on: October 16, 2024, 12:18:24 pm »
Hi dear all
I am Liu, from China HWGC SMT Manufacture, and it's hard for me to use this EEVBlog, i don't know how to post the new sotware and catalog here.
If any of you need update software, and need machine specification can add my whatsup: 86-15931673319, E-mail: sjzwglw@163.com
Best Regards
Liu
Offline liuhwgcsmt
  • Country: cn
  • HWGCSMT. Liu
« Reply #373 on: October 18, 2024, 12:18:01 pm »
Hello dear Friend
I am Liu, thanks for your post, it is really appreciate,
But there have some mistakes in your post,
1: in your post there are some old models which we no more produce,
2: the purchase link is not from our factory, all that is from others i don't know who, the resales
3: Price are not correct, price should be consider about the machine config,
4: catalog should be update, but i don't know how to uploade it here
Thanks again dear Friend
Liu
Offline liuhwgcsmt
  • Country: cn
  • HWGCSMT. Liu
« Reply #374 on: October 18, 2024, 12:55:39 pm »
Hi dear
Good morning,
I am Liu, and if need any more feeders or want to update new machine can let me know
Thanks
