No I mean like a backing plate. YOu might be able to cut a copper covered PCB with agressive settings but I mean just so it s fast. You mount the PCB to a sheet, mark it up, cut it, and presto
its less work then actually trying to cut it with jig saws or whatever, but its still
mega lame compared to having a big vise You still need to drill holes for the standoffs in the correct positions and stuff like that.
building any fixture for a REPAIR is freaking horrible. If it was a prototype I can stomach it, but to repair some OLD equipment it makes my stomach churn
Another option is to make a universal backing plate that is segmented, i.e. it has 8 big cut outs in it with panels, so you can mount the board and remove relevant panels to access the rear. but its still custom fitting to position the standoffs. Cleco clips might help make it easier
haha, I wonder what they do for giant ceramic boards (70's-80's military). those repair guys were probobly borderline postal
maybe you can make a adjustable one out of those aluminum rail pieces
they should have made it thicker. boards this big with ceramic should be thicker. its almost floppy.
But for a board this size, I don't think you could even use a standard vise if it was big. Its too floppy, you need like a section to support the middle with like adjustable thumb screws. god what a pain in the ass
