Author Topic: Why you need bulk/loose SMDs?  (Read 2496 times)
Offline olkipukkiTopic starter
« on: September 06, 2018, 11:14:55 pm »
I noticed that you can buy generic SMD capacitors down to 0402... well, puzzle for me, what people are doing with these?  :-//
Online ANTALIFE
  • ( ͡° ͜ʖ ͡°)
    • Muh Blog
Re: Why you need bulk/loose SMDs?
« Reply #1 on: September 07, 2018, 05:27:03 am »
You talking like off eBay/AliExpress? If so some people just want to have something cheap to get them started
« Reply #2 on: September 07, 2018, 05:54:20 am »
Nope, Mouser or DigiKey, for example.
Offline LukeW
« Reply #3 on: September 07, 2018, 06:55:02 am »
Manual hand assembly of experiments and prototypes, repairs and modifications, and hobbyist uses?
Offline SMTech
« Reply #4 on: September 07, 2018, 07:27:31 am »
Very high volume production lines can use bulk packs of surface mount capacitors in special feeders, this makes it easier to keep up with demand, and can result in massive reduction in used tape. Its also super-cool, check out this video from ASM
Or rather more specialised: this bowl feeder for LEDs from Mirae
. The big commercial machines can have all sorts of weird and wonderful custom feeders made for them by the manufacturer or 3rd parties like Hover Davies. Another common one is through hold LED feeders that can bandoliers of through hole LEDs, cut, form if needed, and place/insert. You can also place solder balls, solder preforms, labels or pretty much anything if you have the machine, requirement and tooling.
The following users thanked this post: grifftech
Online ANTALIFE
  • ( ͡° ͜ʖ ͡°)
    • Muh Blog
« Reply #5 on: September 07, 2018, 08:28:01 am »
Ah had no idea you could buy those sort of things from reputable suppliers
Oh wow, had no idea those sort of PP machines/feeders existed. Makes sense, we had one customer that wanted to get their cut up wafer into cut-tape reel, they were a bit shocked with how much it costs
Offline SMTech
« Reply #6 on: September 07, 2018, 08:46:35 am »
Pretty sure you can get a customised machine/feeder that takes a wafer and does the rest :D
Online ANTALIFE
  • ( ͡° ͜ʖ ͡°)
    • Muh Blog
« Reply #7 on: September 07, 2018, 09:07:18 am »
Ah righto, we were going to use our one (MY12) but it turned out the piece of silicon had to be rotated in all 3 axies before it was placed on the PCB
Offline SMTech
« Reply #8 on: September 07, 2018, 09:32:38 am »
IIRC what I have seen online was a case study on the Essemtec website for a custom solution, but it was some time ago and based on an FLX, can't see it on the wayback machine tho'.
Offline mrpackethead
  • D Size Cell
« Reply #9 on: September 07, 2018, 10:05:57 am »
The cost of putting parts on tape can be more than the parts themselves for small passives.
« Reply #10 on: September 07, 2018, 05:15:53 pm »
Wow, looks awesome!
That's cool concept and not yet anyone copied it?!
P.S.
If someone struggle to understand German   >:D
here is English version of above youtube video
The following users thanked this post: blueskull, grifftech
« Reply #11 on: September 07, 2018, 05:29:57 pm »
Me either. I accidentally noticed in KEMET datasheet...
  • D Size Cell
« Reply #12 on: September 07, 2018, 10:10:33 pm »
Wow, looks awesome!
It is a non trivial problem to solve and if you are goign to need to place 10's Millions of the same part, it may be worth pursuing.
