But as far as I know to do that it would be necessary to "pick and place" the brass tubes. Is this something feasible or was it be quite the manual operation?
Greetings Simon,
Whilst everything is possible, it is unlikely that a feeder can be found for the SMD PnP robot for the brass tubes.
If the tube is a tight fit in the hole, then pushing them in by hand before loading the rest of the SMD components would probably be the best method. BUT the PnP robot will need programming to ensure its head does not collide with the brass tubes.
An alternative might be to have the tubes exit through the bottom side of the board. You can then make a holding tool with female holes in it to allow the male brass tubes to "sit inside the holes". This ensures the PnP placing head cannot collide with the tubes.
But the best way of doing this would be to have it soldered in the reflow oven along with every other component.
Yes, this would certainly save time. I would suggest making a thicker (at least 8 thousands-of-an-inch) solder paste stencil to ensure you lay down enough paste for a good joint.
You will need plenty of heat in the reflow oven. Consider pure copper tubes instead of brass. These conduct both electricity & heat much better than brass & will expand & contract at the same rate as the copper on the board.
If the copper/brass tube is malleable enough, you could make up a peening tool to actually peen each end/one end of the tube over the pad.
Depending on the diameter of the tube, wave soldering may mainly fill the tube with solder if the SMD side is left open to the air. If the solder paste covers the top of the tube, the resultant air-lock will likely prevent the tube filling with solder.
Just a few pointers that might help you.
