Author Topic: Unmarked SMD resistors  (Read 8984 times)
Offline JohnnyPTopic starter
    • J&S Electronics
« on: September 18, 2020, 01:31:05 pm »
I received a package of 0805 resistors from Mouser with no marking.  I went online and found this document from Vishay:
https://www.vishay.com/whatsnew/doc/ff_FastFacts_Marking-discontinuation.pdf
"The marking of Vishay’s  standard R-chips in the 0603 to 2512 case sizes — i.e. CRCW0603 – CRCW2512 with TCRof ± 200 ppm/K / 5 %, TCR of ± 100 ppm/K / 1 %, and TCR of ± 200 ppm/K / 1 %, 0.0 Ω — will be discontinued to improve the efficiency of the production process."
Not good for those of us that do hand assembly.
Are all brands phasing out marking?
Thinking is hard work
Offline asmi
Re: Unmarked SMD resistors
« Reply #1 on: September 18, 2020, 02:04:55 pm »
A lot of my boards have a ton of 0402, which are all unmarked, and I have no issues manually assembling them. You don't need any markings for hand assembly.
Online ataradov
    • Personal site
« Reply #2 on: September 18, 2020, 05:30:40 pm »
Capacitors are already unmarked anyway.
This just makes it easier to assemble - now you don't need to think which side is up.
Alex
The following users thanked this post: Smokey
Offline SilverSolder
« Reply #3 on: September 18, 2020, 06:07:58 pm »
I already didn't care!  :D
Offline PKTKS
  • Country: br
« Reply #4 on: September 18, 2020, 06:25:01 pm »
... 2 cents..
well I do care.
I remember that classic movie BladeRunner (original)
when the folk asked for the markings on piece of
snake skin...
readily the old woman found the markings w/a scope.
Nothing can speak better for itself
Electronic parts are way more important than
snake skin and for the sake of responsible issues..
The very same folks which care about  using lead free.
instead of leaded...
well they don't care marking critical parts for
replacement and safety.
There was a time were schematic was bundled
inside the devices and parts were resposible
marked..
That time seems to be long gone
Paul
The following users thanked this post: ANTALIFE
Online ataradov
    • Personal site
« Reply #5 on: September 18, 2020, 06:29:46 pm »
... 2 cents..
WTF was that rant? What doers it have to do with resistor markings disappearing?
Alex
Offline PKTKS
  • Country: br
« Reply #6 on: September 18, 2020, 06:43:50 pm »
... 2 cents..
When you need to replace them...
I do have bricked stuff just because I could not
found a suitable replacement.. for bad SMD parts.
A hell of a waste of time and money.
Anyone already pissed with that lack of markings already know
Paul
« Reply #7 on: September 18, 2020, 07:25:40 pm »
... 2 cents..
Paul
I agree about the missing documentation (and leaded solder!), but resistor values don't have to be marked on microscopic parts...  as long as there is a schematic and a board layout, and as long as you have a pair of LCR tweezers, losing the resistor markings isn't really an issue to me.
    • J&S Electronics
« Reply #8 on: September 18, 2020, 07:48:22 pm »
It looks like Panasonic is still marking 0402 and above.  Refer to page 4 here:
file:///Users/jp/Downloads/id_fixed-resistors_e_1.pdf
    • J&S Electronics
« Reply #9 on: September 18, 2020, 07:53:32 pm »
Yes, I need a pair of LCR tweezers.  I saw Dave doing a test and tear down on some for less than $80, I think?
« Reply #10 on: September 18, 2020, 08:18:00 pm »
Yes, that's a whole discussion in its own right.   The most reasonably priced ones appear to be the Mastech MS8911.  I've got a set of those coming, I like the fact that they can test with a low 100mV voltage to avoid exceeding silicon junction thresholds - so they can be used to measure components in-circuit.
Offline asmi
« Reply #11 on: September 18, 2020, 08:20:05 pm »
I never needed any of that. As long as you've got schematics, you don't need any markings.
« Reply #12 on: September 18, 2020, 08:58:23 pm »
If you are talking about LCR tweezers, I think these are a reasonably new invention (at least at a reasonable cost) and may make things more convenient.
Offline Rat_Patrol
« Reply #13 on: September 18, 2020, 10:00:41 pm »
I run Panasonic resistors (have had excellent results, consistency, available, price, etc), they are still marked. Some resistors I have from other manufacturers are not marked.
The only time it is a PITA for unmarked resistors is when you dump a bunch of components on a bench for hand assembly. My advise is to never do that anyway.
If there is a silkscreen with component ID, I guess I just don't care either way.
Online tszaboo
« Reply #14 on: September 18, 2020, 10:31:22 pm »
I hope this was a joke. Ones side has the film, the other doesnt. Heat dissipation is different based on orientation.
Offline Daixiwen
  • Country: no
« Reply #15 on: September 22, 2020, 06:41:34 am »
Just restrict yourself to only using 10k and 100n, and the problem is solved
The following users thanked this post: ar__systems
Offline ANTALIFE
  • ( ͡° ͜ʖ ͡°)
    • Muh Blog
« Reply #16 on: September 22, 2020, 10:07:34 am »
... 2 cents..
well I do care.
snake skin...
marked..
Paul
Offline SMTech
« Reply #17 on: September 22, 2020, 11:14:39 am »
AOI systems can also use resistor markings for verification, when neither caps or resistors have distinguishing markings its another push towards SMT lines being fitted with component verification units that test parts to check machine loading. If you can build a complex assembly without losing track using unmarked 0402, well yay for you, I'm not going to make that claim because it would be a lie.
We do have one client that uses the marking on a resistor to designate the version of the build so we have to buy a very specific brand to make sure we get the 3 digits they want just for that location.
Offline ar__systems
« Reply #18 on: September 22, 2020, 11:48:43 am »
Your post is a joke. Heat dissipation? For caps? I mean yes it is a thing, but when was the last time you sized a cap for heat dissipation?
Also "one side has film" is not how MLCC are built.
For resistors majority of heat goes through solder joints anyway, so...
Offline free_electron
    • SiliconValleyGarage
« Reply #19 on: September 22, 2020, 12:23:13 pm »
NOT TRUE. The electrode on top is different from the electrode on the bottom !
Offline Kleinstein
« Reply #20 on: September 22, 2020, 01:52:06 pm »
Usually there is no big deal in soldering the resistors with the other side up. It may protect the numbering from getting damaged  :-DD  In RF applications it can make a difference to reduce the inductance. Cleaning could be more stress to the film side closer to the board and trapping some fluid there
It is convenient to have the numbering on hand soldered circuits, so one has it easier to check if there was a misplaced resistors. So one needs to be more careful if they all look the same. In the beginning it would be only a few values with no markings and the old stock still marked. The higher grades still seem to be marked.
For 0.5 cent resistors the marking can be a significant part of the costs if there are some looking for the last percent cost savings.
There is no need to get to 100 n and 10 K only - there are still different sizes. capacitors can also be different color usually more brown with X7R and more white with the better C0G ones.
Offline NorthGuy
« Reply #21 on: September 22, 2020, 01:53:19 pm »
I like the markings. When I do prototypes, I can easily check that I soldered correct resistors at correct places. Measuring resistance in-circuit isn't always possible.
Offline perieanuo
« Reply #22 on: September 22, 2020, 02:32:24 pm »
long live capitalism!!!
they cut costs and eliminate after-market repairing with one bullet.
some resistors values are critical.they should be forced to give you the schematics in this case.
hope they die eaten by a giant werewolf
Offline Kjelt
« Reply #23 on: September 22, 2020, 02:44:37 pm »
Just a big nuisance if you order a sample package of resistors, 100 of each value and you have to remeasure each strip for the correct value.
Repair  :-// most resistors that die, are unreadable anyway, browned out hole for the chimney the magic smoke escaped from.
Reverse engineering yes, now you really have to desolder the resistors and measure to be sure.
Offline TimFox
« Reply #24 on: September 22, 2020, 03:03:21 pm »
I remember when we had a strange problem in the field, with a large set of SMT boards in an array.  Some of them were responding differently with a dynamic situation (not at liberty to discuss details).  It turns out that the "odd" boards were correct.  Somehow, 1 nF and 10 pF capacitors (both values were on the board) had been interchanged during board stuffing (same case size and color, but SMT capacitors are almost never marked).  Luckily, there were a couple of the boards from the same lot back at our lab, and a tweezer measurement verified the problem.
