Trying to get JLC to successfully ingest my Zip'd files. Can't seem to do it.
The Eagle ZIP file are on this page:
https://tangentsoft.net/audio/pimeta2/dfiles.htmlUsing several versions of Eagle (from 5.x to latest), I converted - -in several attempts -- to Gerber using this tutorial:
https://support.jlcpcb.com/article/43-how-to-export-eagle-pcb-to-gerber-files(I have successfully done this for other projects from Tangetsoft.net) .
But, this time, I see no Gerber view images and the PCB dimensions are missing.
Analysis Results
layers : -1
minimum trace width : >=10 mil
minimum trace spacing : >=10 mil
minimum drill size : null
width : null
height : null
Analysis Results
Unable to identify the layers due to the non-standard filename
Can not identify the board outline
The new Gerber Viewer doesn't support files upload before July, please re-upload on our quote page to try the new version.
I went to PCBWay.com, up'd the same zip'd Gerber. Got a little further. PCBWay got the dimensions correct and I got to see two images (TOP and BOTTOM) but the trace pattern was a small square in the corner of the green PCB.
If anyone of you want to take a shot, please proceed and make a "duh" fool outta me
