The link of Tronstol E4:
https://youtu.be/fBYNy7gVhmQAfter more than 10 years of technological accumulation(we are the original team from Neoden), Tronstol E4 is a high-end version of Tronstol E1. We have always focused on R&D and innovation in the field of SMT. Precision meets efficiency with our intelligent pick and place machine Tronstol E4, revolutionizing assembly with cutting-edge technology.New intelligent feeder system with our unique library database makes placement so easy.
Here are some details of E4:
For the hardware:
1.Through the combination of screw drive and servo motor, precise motion control and quick response are achieved;
2.The grating ruler motion system can feedback position information in real time to ensure the accurate positioning of the placement head in three-dimensional space.
3.The motion control system installed on the one-piece square steel frame ensures the stability of placement and the durability of the machine.
4.The three-section track allows the placement machine to handle multiple circuit boards simultaneously. This increases the overall efficiency of the machine, reduces idle time and increases output. The track uses an electric top plate: driven by an electric motor, the movement position and speed of the top plate can be precisely controlled.
5.
The new patented intelligent feeder has its own memory function. Each feeder is locked to a material. After the feeder is disassembled and replaced, it can be used without editing. It is highly convenient and intelligent.
6.The vision system uses 4 CCD laser flying cameras and 1 Mark camera to achieve shooting while walking, high-speed positioning, and high-precision identification. When combined with a dark vision HD camera adapted to low-light environments, the E4 is suitable for a variety of application scenarios for complex surface mounting.
7.It can support standard tap&reels, standard IC trays, short tape trays, vibration feeders and bulk materials.With the auto nozzle changer 8 different models of nozzles can be used together.0201,BGA,TQFP can be mounted.
For the software:
1. Friendly user interface design, convenient for customers to use.
2.
Material and feeder library: the same component does not need to be edited if you change different PCB.It really reduce the time to install the tape&reel and edit the stack information.You only need edit once for the pick height,pick delay...this function can really save your time.The function of the material library saves the time of repeated editing of materials. After optimizing the material library, it can realize direct posting without editing.
3.Offline software:you can edit you file in your computer.It will not occupy the machine.
4.The self-designed software has powerful functions, high flexibility, and real-time updates and iterations.
5. It supports simultaneous use of tape, tube, short, IC tray, and bulk materials, especially the bulk material function, which allows customization of bulk material templates for various sizes, shapes, and types of components.And if you want to mount bulk material automatically,you can update E1 plus which has the vibration feeder tray.
6. Automatic correction of picking position,it help you edit the file more quickly.
7.Flexibility in Mark selection:You can use none mark,one mark,two marks or any quantities of marks
8. Visualization of each hardware communication node makes maintenance and debugging easy...
