I use it on production designs, on request.
Altium's automatic generation seems good enough, and I haven't heard any push-back from it. Mind, production may optimize the design further after I'm done with it.
It's not very meaningful for proto designs, if that's what you're doing. It's a production yield optimization -- or, if your footprints (mostly thru pad annular rings) are so insufficient that proto yield even is poor, you should probably address that first(!).
