I have a 44-pin PLCC surface mount IC socket that I soldered. Initially I thought just being careful would allow me to solder it, however, I quickly learned that no matter what, I would melt the plastic bottom due to shaky hands.
YouTube videos show to cut out the bottom and wondering if this is the normal practice (I don't have any professionally soldered IC sockets to see whether the plastic is cut out)?
I should have looked on YouTube first, but figured: I can't use hot air because I'll melt the socket, and the only way to solder it is to get in there with a steady hand.
