I have myself a NEO-M8T module to make a GPSDO, but I need a board to put it on. I thought of buying a Chinese GPS board and removing the module on that, to reuse the board. The pinouts are the same.
The first attempt didn't go well for either the module (not bothered) or the PCB, which ended up with practically no pads left on it. That was with a Weller pencil iron, binocular microscope and ChipQuik. I guess either my kit or my skills just aren't up to removing it that way. I think my ChipQuik is leaded though, and the board wasn't.
I'm thinking of trying another by simply heating the whole board on a hot plate and picking off the module. However, the first module was also stuck down to the PCB (which also probably played a hand in its destruction) so I'm not sure if heating it up is going to do the trick. Or if it's even a good idea anyway.
Suggestions are most welcome!
A picture of the board is attached.
