Author Topic: TO220 middle leg bend-out tool  (Read 2004 times)
Offline FaringdonTopic starter
'Perfection' is the enemy of 'perfectly satisfactory'
Offline Gyro
Re: TO220 middle leg bend-out tool
« Reply #1 on: September 29, 2023, 06:43:00 pm »
That's a tool for bending and forming open lengths of wire and strip, it will be totally useless for selectively bending just the middle leg of a TO220 pkg repeatably or otherwise. It is not the cheapest tool for the purpose as it doesn't work. Do you agree?
Best Regards, Chris
The following users thanked this post: Faringdon
Offline mariush
« Reply #2 on: September 29, 2023, 07:05:46 pm »
Have you looked at these ?
central lead formed 5.08 mm https://www.dpv-elektronik.de/Products/Tools/Pliers/Bending---Forming-pliers/Bending-pliers-TO-220-5.html
central lead formed 3.81 mm https://www.dpv-elektronik.de/Products/Tools/Pliers/Bending---Forming-pliers/Bending-pliers-TO-220--90-.html
side lead formed 3.81 mm https://www.dpv-elektronik.de/Products/Tools/Pliers/Bending---Forming-pliers/Bending-pliers-TO-220-4.html
side lead formed 2.54 mm https://www.dpv-elektronik.de/Products/Tools/Pliers/Bending---Forming-pliers/Bending-pliers-TO-220.html
central lead formed 2.50 mm https://www.dpv-elektronik.de/Products/Tools/Pliers/Bending---Forming-pliers/Bending-pliers-TO-220-3.html
and others... a whole list at the bottom of the pages... They say in stock but who knows
You could probably easily 3D print some plastic tool to bend the leads.
For example, I'm thinking something in two steps, a first part just big enough to lock the to-220 in place and to block the leads up to the point where you want to bend the lead. Then slide the part into a bigger part that would make the  bend on the center lead... squeeze the tool to bend the middle lead to the shape you want.
Optionally you would want to have a version for 5 pin to-220 or other versions.
The following users thanked this post: spostma, Faringdon
Offline David Aurora
« Reply #3 on: September 29, 2023, 11:35:16 pm »
Is this the cheapest repeatable  TO220 middle leg bend-out tool?
Hi.
No.
Hope this helps.
Offline Kim Christensen
« Reply #4 on: September 30, 2023, 02:46:29 am »
Have you checked with the manufacturer if a version of the part comes with preformed leads?
Offline Kean
    • Kean Electronics
Offline jfiresto
« Reply #6 on: October 02, 2023, 08:17:49 am »
and others... a whole list at the bottom of the pages... They say in stock but who knows....
They did when I bought a couple early this year. Another source may be tme.eu. They were also selling Piergiacomi tools for ca. 50% more, but also to non-trade customers.
EDIT: Here is another source I found.
« Last Edit: October 02, 2023, 08:21:24 am by jfiresto »
-John
