I'm trying to reverse engineer a small board from a proximity sensor. The only thru-hole component on it is a 2SC2655 transistor. While there are many versions out there, I haven't found any with the "WH-Y" marking on them.
Any help deciphering the meaning of that marking and what smd equivalent could be used would be hugely appreciated!
Much thanks!
