Author Topic: Smallest VIA size on pcbway without extra cost  (Read 1103 times)
Offline mrburnsTopic starter
  • Automation engineer/coder. Electronics Hobbyist
« on: July 15, 2023, 06:39:43 pm »
I was unable to find out the answer from the pcbway website that what is the smallest VIA size on pcbway without extra cost. This question is related to my other post on the beginners forum: https://www.eevblog.com/forum/beginners/(pcb-review-request)-pi-zero-breakout-for-sensors-3-30v-regulated-input/
Offline ataradov
    • Personal site
Re: Smallest VIA size on pcbway without extra cost
« Reply #1 on: July 15, 2023, 06:53:34 pm »
At least If you try to place the order, you are given multiple options. 0.25 mm is the smallest at the same price. At 0.2 mm you get a significant bump on prototype quantities. The increase is less significant on the large quantity orders. And at 0.15 mm, the price increase is even more significant.
Alex
Offline DavidAlfa
« Reply #2 on: July 15, 2023, 07:02:45 pm »
Same as jlcpcb, 0.3mm drill hole, I used 0.4mm vias without problem.
Check this picture out for details.
Good luck soldering the TPS55289!
Why choose a so complicated device/footprint?
The're gazillions of buck converters capable switching 24V into 5V 500mA, and you have enough free space in that board for several football fields :-).
« Last Edit: July 15, 2023, 07:18:35 pm by DavidAlfa »
« Reply #3 on: July 15, 2023, 09:26:27 pm »
I will order the PCB with all SMDs assembled. I hope that they are able to pull that off.
As of why this decided to go with this device is that Im really looking forward to test and experiment with the I²C interface of that chip. For this and future use.
So if I try to keep the VIA diameter at 18mil and I put hole size to 10mil would they be able to do it without extra cost?
