Author Topic: RF PCB House?  (Read 4703 times)
Offline EricVanWykTopic starter
RF PCB House?
« on: July 22, 2014, 04:35:31 pm »
I'm looking to do a couple 4 layer PCBs that have RF components in the 5-7GHz range.  Does anyone have a favorite house for doing these sorts of things?
Offline free_electron
    • SiliconValleyGarage
Re: RF PCB House?
« Reply #1 on: July 22, 2014, 04:56:38 pm »
whaddaymean ? to do the layout work or to make the bare board ? any serious board house can make this. Pick one of the Nelco or Rogers RF substrates , pick the layer stackup , plug the numbers and off you go.
Re: RF PCB House?
« Reply #2 on: July 22, 2014, 08:02:12 pm »
To make the bare board.  I have my favorite houses for high current, and another set for "cheap crap quick", but I don't yet have a favorite house for RF.
All of my RF work has been either 900M or 2.4G, and honestly wasn't all that complicated - mostly I did antenna design or front ends with just a handful of RF components.  This will have a few copper defined components (filters and splitters) and is more sensitive to interference than other designs I've done.
What is your favorite "serious board house" for this?
Thanks!
 - Eric
Offline Dago
    • Electronics blog about whatever I happen to build!
Re: RF PCB House?
« Reply #3 on: July 25, 2014, 11:06:37 am »
I know PCBcart (chinese shop, ok place) offers RF-substrates at least: http://www.pcbcart.com/ No experience with their RF-boards though. I have a bunch of friends who have ordered regular boards from there without a hitch though. I think you need to email the design files to them to get a quote for RF-boards, can't use their automatic quote.
Come and check my projects at http://www.dgkelectronics.com ! I also tweet as https://twitter.com/DGKelectronics
Online nctnico
Re: RF PCB House?
« Reply #4 on: August 21, 2014, 10:41:36 pm »
Where are you located? Eurocircuits offers Rogers material IIRC.
Offline Dago
Re: RF PCB House?
« Reply #5 on: August 22, 2014, 06:13:27 am »
Also Brandner (https://www.brandner.ee/) has Rogers RO4003C in their stock list but I have never ordered an RF PCB from them. Plenty of other boards though with very good service.
Offline Chris Jones
Re: RF PCB House?
« Reply #6 on: August 24, 2014, 08:55:10 am »
If you are in Australia, http://www.lintek.com.au/ are good. Their design rules document http://www.lintek.com.au/resources/datasheets/Capabilities%20and%20Design%20Guide%20V2.4.pdf is very clearly written.
Offline IconicPCB
Re: RF PCB House?
« Reply #7 on: September 07, 2014, 11:57:20 pm »
Chris,
Iconic PCB make bare boards in Brisbane using mechanical milling process. Mechanical process will provide a cleaner edge profile than chemical etching.
They have made some cavity boards in Rogers material in the past.
www.iconicpcb.com
Offline Alexei.Polkhanov
Re: RF PCB House?
« Reply #8 on: September 08, 2014, 05:37:47 am »
Interesting. From your experience, besides 3D-iness and miniaturization does "cavity board" give any other advantage over simple planar board? Which CAD tool do you use?
Offline IconicPCB
Re: RF PCB House?
« Reply #9 on: September 08, 2014, 07:31:04 am »
The process relies on mechanical etching. Gerbers are processed by Graphicode Gerber editor which also generates G code.
Cavity structure was a part of resonator design.
