you might seriously consider using a saucepan+sand on a gas hob.
I agree there are many methods. I wished I had found this thread a little earlier as I would have recommended a halogen air cooker over the toaster ovens mentioned above. We used one quite regularly in a laboratory I was working in for some months.
They work very well, with the temperature above the PCB being pretty much the same temperature all over due to the hot air being blown around by the fan.
Sit the board in the lower 10cm of the oven on a metal rack covered with alfoil (shiny side up). There is a thermostat that will click in & out over about 10 degrees C.
Here is a uTube video of the oven that we used:
And here is one such unit on sale for AUD$69 (approx US$50):
https://www.goprice.com.au/singer-halogen-convection-ovenIf you use leaded solder, make sure you clean the oven out well before using it to cook your next meal.
