I've got access to the universal manuals / voyager but I haven't found a section that describes the feeder teach setup process, I can pick up the teach slug onto the conveyor and then get into feeder teach but if I teach the corners of the slug as the on screen prompts suggest (bottom left then top right in the feeder location to pick location action) it doesn't give me a valid offset. I have worked out a currently working solution, but I would be keen to know the correct way to do this. I laser cut a copy of the PTF teach slug and tray, then covered the laser cut copy of the teach slug in white board marker. I then ran the teach product in NPI mode with board transport turned off. I measured the offset from the ptf nozzle mark and the high force head nozzle mark, then adjusted the pick position so it picked in the centre. So it works now but it's not as elegant as actually knowing how to do it correctly!
