Author Topic: Professional assembly mishaps  (Read 29860 times)
Offline Yellofriend
  • Country: hk
Re: Professional assembly mishaps
« Reply #50 on: October 18, 2017, 02:59:56 am »
All manual insertion and manual soldering. All old ladies chatting as they were working.
That's what we did when I worked in an assembly factory in China a long while ago. All manual, each person maybe 3-5 parts. Only difference, our ladies were young. Zero problems with missing parts or polarity. The method can work, but nowadays too expensive I guess.
TVM802C - now with OpenPnP
T962A
Offline zeqing
« Reply #51 on: October 27, 2017, 08:35:07 am »
Agree, the salary in China doubled, or even Tripled in the past 10 years.  manually soldering is expensive and only suitable for the prototyping 1~5 pcs production.
Offline nanofrog
« Reply #52 on: October 27, 2017, 11:48:03 am »
I'd add rework or repair of high-value products.
Online Ice-Tea
    • Freelance Hardware Engineer
« Reply #53 on: October 27, 2017, 03:15:58 pm »
Partially my own fault but:
I once made a small mod to a design while on holliday in France. Send out Gerbers without checking (only a small change, just this once it will be fine!). The outjob was bad and two layer were 'blank'. The assembly house produced it and everything was shorted together as every via would be connected to two solid sheets of copper on the mid layers.
Still can't believe nobody at either the assembly house or board house caught it.
Offline JuKu
    • LitePlacer - The Low Cost DIY Pick and Place Machine
« Reply #54 on: October 29, 2017, 02:45:13 pm »
My favorite assembly mishap:
http://www.liteplacer.com - The Low Cost DIY Pick and Place Machine
Offline capt bullshot
« Reply #55 on: November 09, 2017, 10:57:02 am »
Some time ago, I had this one
Inappropriate manual handling of the boards after reflow
Offline Leo BodnarTopic starter
« Reply #56 on: December 08, 2017, 08:22:26 am »
Few more from today.
Offline Mr. Scram
  • Display aficionado
« Reply #57 on: December 08, 2017, 08:29:29 am »
That first one looks like someone got fed up with it and threw some parts in the general direction of the board.
Offline l0wside
« Reply #58 on: December 08, 2017, 01:45:01 pm »
No pictures, but still my very first assembly run (mid-size PCBA company in southern Germany) cost me a bunch of nerves:
  • I had sent them an extra picture of the board, showing polarity or pin 1 for each component. Result: out of 100 parts, 100 had the electrolytic caps the wrong way round. They fixed it manually at their cost, but I still lost at least two weeks.
  • The design has a tactile switch. Roughly half of the switches did not work. Turns out they washed the PCBs after assembly (which is not uncommon). Washed-out flux got into the switches and blocked them mechanically. The datasheet states clearly "Washing: Not possible". They fixed it manually at their cost...
  • From previous tasks, I am used to using no-clean flux. I have a sensor on the board which has a protective cap...that was washed off in the process.  Some covers were still on, some dangling around, most had been washed off. QC seems not to have cared. To be honest, it was at least partly my fault - I had simply not considered washing.
Offline fcb
    • Electron Plus
« Reply #59 on: December 08, 2017, 03:54:29 pm »
They can't possibly have gone through AOI or any form of inspection.
Offline sokoloff
« Reply #60 on: December 08, 2017, 04:52:41 pm »
It would be more disturbing if only 63 (or 17 or whatever) were the wrong way 'round!
Offline asmi
« Reply #61 on: December 12, 2017, 05:10:22 pm »
My own oopsie that happened this weekend  ::)
Decided not to fix as it's a 0201 cap which is too close to the DDR3L IC so that I couldn't get in there with an iron without risking damaging the IC. The module works at full speed just fine even without one cap :phew:
Offline zeqing
« Reply #62 on: December 15, 2017, 08:52:10 am »
0201 is indeed risky for some soldering factories, avoid to use 0201 package unless you are design PC/phone....
Offline zeqing
« Reply #63 on: December 15, 2017, 09:09:46 am »
this kind of problem occurs some times, when i make the PCBA, my vendor makerfabs will make a sample and take detailded picture for me for checking. although very rare i found mistakes,  it make me ease...
it needs experience for the vendor,almost impossible for the soldering man to check the datasheet, but it is really very basic knowledge that most of switches can not be washed by flux
most of factory use the soldering that need to be washed after the soldering, or the PCBA would be looks urgly- as they may think so normally they will wash after the THT soldering.  most sensor for the Environment can not be washed ... that you should remind them, unless your soldering vendor themselves is electronic engineers and know the notes. i suggest you my long-term PCBA vendor Makerfabs, really help me a lot in the DFM and solves my problems in their side.
« Last Edit: December 15, 2017, 09:11:17 am by zeqing »
Offline Kean
    • Kean Electronics
« Reply #64 on: December 15, 2017, 04:55:23 pm »
@zeqing Almost every other post of yours you mention the name of your "vendor".  Please stop with the shilling!
The following users thanked this post: wraper
Offline zeqing
« Reply #65 on: December 16, 2017, 01:57:23 am »
@kean  here's not your personal back garden and stop shouting to others with your uncivilized manner.
Offline wraper
  • Country: lv
« Reply #66 on: December 16, 2017, 02:25:52 am »
No, it's you who treats this forum as a personal spam garden. Frankly, after reading your posts, I have strong suspicion that you could be makerfabs marketing shill and should be banned if that turns out to be true.
Edit: Actually you are a shill and admitted it in one of your posts and just got reported.
nice to meet you here,   how is the project krunch king now? :)
I stopped selling them, putting it through a redesign after all the hardware issues I had. Where do I know you from?  8)
i run a PCB assembly studio in shenzhen called makerfabs with some friends, and once i quoted for you.... your name really special that i still remember you after 3 years... :-DD
« Last Edit: December 16, 2017, 02:41:35 am by wraper »
The following users thanked this post: Kean
Offline zeqing
« Reply #67 on: December 16, 2017, 02:50:46 am »
yes, i have been there for half an year and still now we have had good cooperation on my PCBA and good relationship personally, and i try to help them but without bribery. i do not think the word "shill " impartial for me. strong attitude not works but report me as spam, unless your words nonsense.
Offline wraper
  • Country: lv
« Reply #68 on: December 16, 2017, 02:54:14 am »
Keep lying. Look your quote in my previous post from which is obvious you worked there at for at least last 3 years. You are shill because you said you were ordering from them while actually are working there.
Offline zeqing
« Reply #69 on: December 16, 2017, 03:06:17 am »
you confused and Biased. as i know, the makerfabs only created for about 1 year ago(check their site with alexa!), how could i work there 3 years ago..
"your name really special that i still remember you after 3 years... :-DD"
that is to say many years ago when i was in another company .  do you want me open my resume for you?
« Last Edit: December 16, 2017, 03:10:41 am by zeqing »
Offline wraper
  • Country: lv
« Reply #70 on: December 16, 2017, 03:11:37 am »
you confused. as i know, the makerfabs only created for about 1 year ago(check their site with alexa!), how could i work there 3 years ago..
And I also should believe you are from Germany  :clap:. It could be different Chinese company back then, but it doesn't matter. The fact is you claimed yourself in that post you are running this business. While in the rest of your posts you claimed you buy things at makerfabs.
« Last Edit: December 16, 2017, 03:16:00 am by wraper »
Offline zeqing
« Reply #71 on: December 16, 2017, 03:17:36 am »
maybe you should firstly answer my questions. have you checked the site registration date, as  you believe i have been there for 3 years.
i have answer your questions with "left".
« Last Edit: December 16, 2017, 03:19:15 am by zeqing »
Offline wraper
  • Country: lv
« Reply #72 on: December 16, 2017, 03:21:10 am »
I checked, 2016. But it does not change the fact you wrote yourself that you are running makerfabs.
Offline zeqing
« Reply #73 on: December 16, 2017, 03:24:37 am »
OK, so you have admired your mistakes? how would i explain the "left"? :-// please check my above posts.
this is "Manufacturing & Assembly" and the post  for "assembly mishaps", i think this is a good place to share my  experience, and caught as a "shill" |O
« Last Edit: December 16, 2017, 03:31:30 am by zeqing »
Offline Kean
    • Kean Electronics
« Reply #74 on: December 16, 2017, 06:47:43 am »
Hahaha!  That's hilarious!  I didn't shout nor was I uncivilised.
You have now been reported to the moderators.  I hadn't done that before, I just stated facts and asked you to stop misrepresenting your "vendor".
