Hi
I have a PCB that uses thick copper and has through holes with no thermal relief. The boards were professionally assembled with SMT components on both sides and through-hole (large connectors etc.) on the top, but I need to add motor drive module that goes on the bottom side with through pins coming through to the top. I have good soldering iron and heat gun, but it's not enough.
I asssume that preheating the board will help a lot, and I'm trying to find the right equipment. The board is 180x120mm which rules out a lot of the small cheap heaters, and the module is 22mm tall so anything that just heats a local area probably won't do it. I think I need something to soak the entire assembly.
I need to buy something off the shelf in the US. I do not have time to build a DIY toaster oven, nor time to wait for something from China. I don't have a budget in mind, but I don't expect to use this regularly so I'd rather not pay too much money. If it's more than say $500 I would be better off just finding someone else to do the job for me.
Does anyone have any good suggestions?
Many thanks.
