Did you check out my link? $75 for 250g.
Other threads have mentioned unavoidable losses around 1g per cycle, obviously more for a sloppy system.
I didn't before, but now I have and hey, they are located about 2-2.5 hours north of me here in Florida. Pretty good pricing, relatively speaking, and starting off at much smaller quantities, too. I don't think 250g will be quite enough for what the OP is after, but 1kg should be plenty (7kg would be downright excessive).
It's easy enough to reduce losses using a reflux condenser as I mentioned before and, besides, this stuff is apparently 10k worse than CO2 as a greenhouse gas (even high boiling point liquids like this give off some vapor at room temperature).
That said, Kjelt makes a pertinent observation about exposing the boards to reflow temperatures for too long. I'm not liking any of the ways I've come up with off the top of my head to get around this (basically involving putting the board in *after* the solvent has come up to temperature then removing it after all the paste has reflowed).
So, yeah, I guess it might be a fairly hard problem to solve and probably not worth the trouble.
