Hi guys,
TVM920 Dimensions
These are the dimensions provided to us by QiHe which, on a 'quick check' appear to be correct.
This drawing was done for both our TVM920 and the Torch Reflow Oven [hence the dual set of dims]. The QiHe TVM920 dims are in BOLD RED, so you can ignore the other dims marked 'Torch'.
I hope this assists you in preparing for delivery.
Operating Height of Machine
Industry standard appears to be 900mm [in some cases +up to 50mm, so 950mm].
[I have opted to settle on 900mm however]
Monitor & Keyboard
TVM920 comes equipped with a Swivel Monitor Arm already mounted to the R/H side of the machine. It also has a Bolt-on 'shelf' designed to support a keyboard, but without sufficient space for a mouse to operate easily. I plan to use a roller 'chest of drawers' for Keyboard & Mouse, and to store accessories etc.
Access to Machine when Feeders are Loaded
This should not present an issue as approx half the feeder depth is positioned 'inside' the machine. This is also an industry standard approach it appears.
Good luck - Peter
