Hi all,
This is the best information I could obtain from QiHe.
Regrettably, they don't seem to recognize that a SW/FW release is for ALL users, and not only a response to those how requested the fix/feature initially [this seems to be a fairly common experience with many small Asian manufacturers/suppliers we've dealt with, in that they can't [or won't] step out of their 'own shoes' and into those of their 'customers' every now and then - I don't know how to convey to them just how important this 'step' really is, and how much they would benefit from it].
I tried to get better descriptions of the Initial Request, and how it can be repeated, alas without success.
Hope this helps some of you anyway, and for those who believe they 'recognize' the origin of these fixes/features, it would be great if you could take the time to 'expand & share ' the information on this blog.
Cheers - Peter
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~2017/06/24 V1.311. Fix Multi-PCB results in error
2017/04/25 V1.301. Increase the No. 1 nozzle can not be used for the front 27, 28, back 1, 2 feeder.
No. 2 nozzle can not be used for the front 28, back 1 feeder.
No.3 nozzle can not be used for the front 1, back 28 feeder.
No. 2 nozzle can not be used for the front 1, 2, back 27, 28 feeder.
2. The XY axis can not be moved when the Z axis is not zero
3. Corrected three points to determine the English version of the material trays algorithm UI text error
4. The same line can be used to modify the "test" item
5. Corrected the number of times to abandon, and did not alarm
2017/02/23 V1.291. Fixed after network reconnection automatically load parameters, the interface and internal parameters inconsistent bug
2017/02/11 V1.281. After re-editing, the components completes mark is wrong bug
2. Pick material coordinate order error
3. English version X axis positive limit alarm display error
2017/01/15 V1.271. Modify components arrangement failed bug
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~QiHe release new version of TVM920 Application
I was speaking with Daisy from QiHe yesterday and she confirmed that they have just released version 1.31 of their application.
Contact them by Skype or email to have them send you a copy. I've not yet loaded it so I can't say anything about its functionality.
I have also asked Daisy to send me a list of Bug Fixes/Changes/New Features contained in this release and expect to receive that info sometime today. I'll post it once I receive it.
Cheers - Peter
