Author Topic: PCB XY table  (Read 4042 times)
Offline mattbrockukTopic starter
PCB XY table
« on: December 07, 2016, 03:32:30 pm »
Hi guys
I'm sure theres loads of these but I've not managed to find the right google term for it.
I'm after a PCB holder thats on a X&Y precision stage (with micrometer dials?). I'm thinking of rigging something up (probably use a mill compound stage), but i can't believe this doesn't exist already. How do all these BGA rework $100 specials on eBay work.. surely when you come to put the BGA back on, you need to accurately shift the PCB about by tiny amounts to get it all aligned properly.... or a tight pitch QFP being reworked...
Thanks in advance
Matt
Offline ebclr
Offline cmantunes
« Last Edit: December 08, 2016, 08:43:12 am by cmantunes »
Offline richardlawson1489
    • PCB Assembly
Re: PCB XY table
« Reply #3 on: December 30, 2016, 07:13:20 am »
Great ebclr. Please provide details of using this. This may helpful to me for my project.
Offline ebclr
Re: PCB XY table
« Reply #4 on: December 31, 2016, 03:01:26 pm »
This picture is self explanatory
Offline cdev
Re: PCB XY table
« Reply #5 on: December 31, 2016, 04:12:14 pm »
I am interested in either buying or joining together with others on a project to build something like that to help with precise positioning and then drilling holes.  So what I guess I am looking to buy or build is a subtractive xyz table.
Like a 3D printer in reverse.
(The same jig could also likely also eventually engrave a PCB but small steps first, right now I would just be happy to simply drill the via holes in a more precise, controllable, rapid way.)
Doesn't have to be anywhere near as precise as the device in the animated GIF.
Offline ebclr
Re: PCB XY table
« Reply #6 on: December 31, 2016, 06:47:51 pm »
Like this
Offline cdev
Re: PCB XY table
« Reply #7 on: December 31, 2016, 10:44:53 pm »
Is that your creation?
Google tells me its a CNC found on aliexpress and taobao.com
« Last Edit: December 31, 2016, 10:50:09 pm by cdev »
Offline glenenglish
  • RF engineer. AI6UM / VK1XX . Aviation pilot. MTBr
Re: PCB XY table
« Reply #8 on: January 01, 2017, 06:07:22 am »
Try and get one with ball screws, rather than what is in that photo...
Matt something that would be WELL GOOD enough would be the 3040Z CNC platform
You can buy it for about USD550 delivered, (without steppers or control PCB) (You don't want the ones they supply.)
sales16@lybga.com
it is called the "UNASSEMBLED KIT". I have bought a few from these guys. just tell them to put extra packing on the corners.
there is also a bigger one the 6040Z available in light and heavy versions. again flatpack, no steppers or controller @ 780 inc shipping
and then a 6090Z....
the 3040Z is big enough for any PCB.
I have used one for my paste dispenser, and teamed it up with 3 x $87 closed loop NEMA23 steppers....they have inbuilt drivers, - just supply pulses to drive them......
http://www.cntopstock.com/nema-23-1nm-142ozfin-integrated-closed-loop-stepper-motor-36vdc-jmc-ihss573610-p-5376.html
that is what I use
or if you want higher top speed :
http://www.cntopstock.com/100w-nema-23-029nm-integrated-servo-motor-36vdc-3000rpm-jmc-ihsv57301036-p-5368.html
cheers
« Last Edit: January 01, 2017, 06:47:28 am by glenenglish »
Offline technotronix
    • PCB Assembly
Re: PCB XY table
« Reply #9 on: January 03, 2017, 12:37:54 pm »
I love the idea. Thanks for sharing picture ebclr.
