Hello! I've just received the first PCB I designed myself, from JLCPCB. Nothing fancy, just the defaults - 1.6mm thick, 2 layer, green, HASL, etc. All through hole and kept simple (no tight traces or anything)
They look great, and I've certainly made mental notes of some things I'll change for my next design (maybe larger pads for easier soldering), but one of the boards has a defect; the HASL is smeared about 2mm to the right down the right hand side.
Of course I don't expect 100% success for $2 + shipping, and I factored that in when selecting quantity. But when I've seen other people get bad boards there's usually a big cross on it. Does this mean that it might actually be a design error on my part? I had a look for examples of HASL being smeared online but couldn't find anything.
Thank you.
Hello everyone,
JLCPCB will sincerely accept any quality complaint. As we know no factory can achieve perfect production, we never deny it as well. For the quality problem please contact lilyyang@jlcpcb.com for a solution or claim.
JLCPCB's manufacturing process has passed the following certifications.
We have adopted strict quality control and management to reduce the possibility of errors, including Raw Materials Guarantee, Advanced equipment, Multiple Testing Before Shipping (≥2 layers will always be 100% tested with a flying probe), Strict Management. JLC’s quality complaint rate orders around 0.23%.It is not a marketing strategy but an explanation for our manufacturing results.
We want to find a solution that is satisfactory to both parties, so we adopt a compensation system for losses caused by quality problems. Quality is the life of a product, and it is also the primary production standard for JLCPCB because this is an important factor that can maintain JLCPCB competitiveness. Thank you for your valuable comments, we will listen carefully.
