Author Topic: parts moving after placement?  (Read 285 times)
Offline loki42Topic starter
« on: Yesterday at 01:30:40 pm »
I'm having a lot of trouble placing a long thin connector (DF40C-100DS from Hirose) all my other parts including 0.3mm pitch parts are placed very well, but this part is much longer than anything else and is often placed with rotation or position errors.
I'm using a custom nozzle as I thought it was moving after the nozzle picked it up, but now I'm thinking it could be moving after it's placed. The paste has basically no marks on it, and the parts can be easily moved with even the lightest tap on the board. How should I fix this? Increased placement force? Stickier paste? Placement is with a UIC GX11.
Offline Aspartame
  • Country: tr
Re: parts moving after placement?
« Reply #1 on: Yesterday at 11:17:08 pm »
Did you check if there i a version with peg/post?
Offline jmelson
« Reply #2 on: Yesterday at 11:41:48 pm »
I have had problems with large, heavy parts slipping on the nozzle during the vision gauging of the parts on my P&P machine.  When I detected that, I went and selected to use a larger diameter nozzle, and that prevented the issue.
Hmm, no marks in the paste?  That may indicate the machine has the wrong component height, and is not putting it all the way down to the board.  Try reducing the height that the machine has been given, then it should bring it down more onto the paste.
Also, a problem that has been driving me a bit crazy is very small, light parts bouncing after perfect placement.  The symptom I see is badly placed parts, wildly off position, with perfect dimples where the leads were pressed down into the solder paste.  This proves the part was initially correctly placed.  I think the issue is that the vacuum/blow off timing for these parts is not correct.  There's a page in the software where you can set these timings for each footprint, and I just have to find the ideal numbers.  This machine is a Quad QSA30A, basically a Samsung CP30 with Quad alignment cameras and Quad electronic feeders.
I'm pretty sure the issue is the nozzle lifts too soon after placing the part, before the vacuum has completely gone away, and that causes the part to lift off the board and the drop off the nozzle.
Not asking for help with this, I know I just have to try a few different settings.
Jon
« Last Edit: Yesterday at 11:44:59 pm by jmelson »
« Reply #3 on: Today at 08:43:58 am »
yes, for the DF40 series there isn't.
I'm running a custom nozzle now (after testing all the nozzles on all my heads... ) and it still is doing it, so I'm thinking it's not the nozzle. If I inspect multiple times it's not moving around. I suspect the component height might be the issue.
Your idea about vacuum / blow off timing is interesting. I might be able to tell it to push in and then dwell.
Offline SMTech
« Reply #4 on: Today at 11:31:31 am »
The other thing you can potentially check is how flat the PCB is and adjust underside support if that seems to vary. This is exaggerated on our system as we use a standalone pick and place that holds the PCB in a fixture rather than with rails. Adjustable supports are arranged under the PCB to help keep things flat, but all this is manual and done by eye/feel. Every time you change over a PCB you risk not quite securing the PCB 100% and over the course of a placement cycle something might shift or flex enough to throw out fine pitch placement. This is noticeable for this like long FPC connectors or large things such as 240+pin QFPs.
If I'm not mistaken you are fitting connectors for a Pi compute module and if memory serves the datasheet explicitly says you shouldn't use 2 precisely because some drift is pretty normal, but apparently the Pi foundation doesn't give a flying *** that this makes it difficult for someone that isn't Sony. Dwell time, nozzle choice, placement pressure (if you can set that), blow off & travel speed are definitely areas you could also fiddle with. You could also potentially dive into your machine diagnostics and double check your vacuum levels aren't marginal indicating a need for a filter change/service or adjustment.
Offline 48X24X48X
  • Country: my
    • Rocket Scream
« Reply #5 on: Today at 02:39:27 pm »
It looks like component height set wrongly. Set the height correctly and add a bit extra pushing it downwards like 0.2-0.3mm.
