Author Topic: HWGC P&P machines - Documentation, Discussion and Info  (Read 107119 times)
Offline stefangem
    • cnc-technics.de
Re: HWGC P&P machines - Documentation, Discussion and Info
« Reply #350 on: May 25, 2024, 01:41:48 pm »
Hello,
can you me help to create a PCB Array. in the manual is this false. I have the smt550.
i will make 2 PCB in X (next to each other). in the software comes always "cannot Edit" when i will GEN PCB.
what are the instructions?
first from the first pcb to a fiducial and than the second pcb to the same fiducial?and than generate?
this has no function. always "cannot edit"
when i make on the plate a IC is this not a problem. but the fuction to make a pcb array is very difficult.
Regards
Stefan
« Last Edit: May 25, 2024, 02:27:42 pm by stefangem »
Offline JacksterTopic starter
    • PCBA.UK
« Reply #351 on: May 26, 2024, 12:10:22 pm »
Hello,
Regards
Stefan
You have to do it during the setup steps after setting the Mark fedicuals.
Offline 48X24X48X
  • Country: my
    • Rocket Scream
« Reply #352 on: May 26, 2024, 12:11:57 pm »
Hello,
Regards
Stefan
I think I have this panel instruction in my videos. Check them out.
Offline stefangem
    • cnc-technics.de
« Reply #353 on: May 30, 2024, 10:37:01 am »
I have done.
you have to mark the fiducial first and go to PCB Array, then the first and the last PCB mark from th fiducials.
Offline Yuriy.m
  • Country: by
« Reply #354 on: August 02, 2024, 07:02:58 am »
Good afternoon, colleagues! the SSD died on the t63. changed, everything was set up. The smd test is taking place. but all positions are in error. Who knows where to dig?
Offline Yuriy.m
  • Country: by
« Reply #355 on: August 02, 2024, 07:05:03 am »
foto
    • PCBA.UK
« Reply #356 on: August 02, 2024, 09:01:44 am »
Did you make a backup of your original one or the SMTprog folder in the C drive when you got the machine?
Offline Yuriy.m
  • Country: by
« Reply #357 on: Today at 11:29:47 am »
it was some kind of glitch... I recreated the project and everything worked. I have a couple of questions, what is the latest software for today? and how do I change the placement of the basket?
