Author Topic: Bought my 1st Pick & place  (Read 2248 times)
Offline ebclrTopic starter
Offline ez24
  • L.D.A.
Re: Bought my 1st Pick & place
« Reply #1 on: June 26, 2016, 05:02:56 am »
Just bought one to pick and place my dog's fleas (I hope)
Offline zapta
« Reply #2 on: June 26, 2016, 05:07:15 am »
I tried one of those passive vacuum pens but had hard time to make it to work. Ended up with a cheap electric vacuum pump which works much better. Good luck.
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #3 on: June 26, 2016, 12:05:36 pm »
These things are totally useless, apart from as a source of a handle and tips to make  a proper tool from. You need a foot-operated pump that supplies continuous suction.
See my viddeo for more info :
Day Job: Mostly LEDs
Offline harry4516
    • www.dj0abr.de
« Reply #4 on: June 27, 2016, 12:04:02 am »
Mike, very well done video, many good ideas.
The trick with the double sided sticky tape brings me on an idea for my PnP machine.
When sticked precisely (by the holes in the 8mm tape) the machine can pick it up directly from the tape,
a good solution for short tapes without reels.
Currently I put short 8mm tapes into a groove to hold them in place.
But when I remove the cover tape, some parts are jumping off due to vibrations, especially if plastic tapes are used.
Now i will stick the 8mm tapes on the double sided sticky tape which holds it strong enough,
thanks for this idea.
And yes, these cheap sucking pens are totally useless.
