Author Topic: cleaning lead-free HASL board before soldering  (Read 1542 times)
Offline 1sciguyTopic starter
« on: July 01, 2020, 08:42:26 pm »
I have some boards that were manufactured with lead free HASL last year and I find that they don't readily flow when I'm soldering with fluxed Kester SN96.5 lead free solder.  It takes about 1.5 seconds to wick the pad even though the through-hole pin flows right away.  If I clean the pad with a pencil eraser prior to soldering, it wicks in about 1/2 second.  So clearly the boards are in need of a cleaning before I sit down to solder them.  Is there a liquid bath meant for pre-cleaning?  I am switching all future boards to immersion gold plating, but looking to use up my old boards.  I've read about 99% isopropyl, but wondering if there is something more aggressive.
Thanks,
John
« Last Edit: July 01, 2020, 09:13:47 pm by 1sciguy »
Offline Mangozac
Re: cleaning lead-free HASL board before soldering
« Reply #1 on: July 02, 2020, 02:23:31 am »
I don't think IPA will work for removing oxidisation (if, as I suspect, that's what has occurred). How many boards do you have to do - it sounds like the pencil eraser method might be the quickest solution? Although I'm sure there would be some kind of chemical available for this process.
It's important to keep unused PCBs sealed up in their packets with silica gel until you're ready to use them.
Offline phil from seattle
« Reply #2 on: July 02, 2020, 05:05:12 am »
This might work - https://rbpchemical.com/product/hasl-precleaner-sl/  I have no knowledge or experience with it though.
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #3 on: July 02, 2020, 06:46:13 am »
thin layer of flux + hot plate should do it.
Email: OwOwOwOwO123@outlook.com
Online Ian.M
« Reply #4 on: July 02, 2020, 08:17:23 am »
Scrub them with a green panscourer?
