Here is my test on panelized board yesterday.
For panelized mode marking points (fiducial), just define it on the first board (left bottom on the machine), before this i define it on all board which just did not work.
Using this mode will localize the placement error within board boundary, not accumulated across panel.
The video above untrimmed, still some more to tweak
- at 1:38 it fail to find the mark point, i do not know why - helped it manually.
- at 2:07 some retry picking part on feeder 4, i found later that the nozzle not aligned good to the center of the pocket.
- at 2:30 feeder 16 on the back doesn't peel (like what TheSteve said), seems the feeder box and peel box not perfectly inline.
Below is the photo of the result, not like before the placement error is much better and about the same on each board.
![](http://s20.postimg.org/js5tsoy0d/Panelized_Test.jpg)
Next i will try to:
- adjust the data coordinates to solve the dimmension error.
- add a dummy first chip with a more accurate refference (now the first chip is R10)
- use via as fiducial, i think smaller diameter is better.
About a week delay from the plan for now...
-ichan
