Below a small test placing 16x 1206 smd resistor from 4 feeders using 4 nozzles, with and without vision - speed is 100% both for run speed and feeder speed.
(Sorry the background music is beyond my control
![Sad :(](https://www.eevblog.com/forum/Smileys/default/sad.gif)
14 seconds without vision and 18 second with vision, turned out as 4100 and 3200 CPH. Non vision speed is below my expectation but seems i still can try to speed it up above 100% speed setting, surprised by the speed with vision.
The placement result is almost the same, below is the result with vision - the pcb use transparent adhesive sheet provided by Neoden.
![](http://s20.postimg.org/g1ab8trfx/N4_Result.jpg)
Funny i still do not fully understand how is the coordinates system works, seems it is different between manual programming and import from file.
-ichan
