@elmood, thanks for the video and the list - if only i already have the machine on my hand then i surely will add some on the list.
On your video, you use drilled hole as "marking point" right? What size is it? How is the resulted placement accuracy?
The machine expects the board reference to be your first part which is an absolute value from 0,0. The fiducial points are then are then a relative value from the first part. This isn't out preferred way of doing it.
The information above is just too important to be missing on the manual.
Edit: just check the tracking, my machine just received by the forwarder company in Shenzhen - hope they ship it to me asap.
-ichan
