Author Topic: Neoden 4 pick and place  (Read 616188 times)
Offline mairo
Re: Neoden 4 pick and place
« Reply #1475 on: December 08, 2019, 12:41:47 pm »
Does any one know if the two Neoden eBay accounts - 'neoden' and 'neodentech' are both legit> I think I have seen the 'neoden' account from before, but now there seems to be also a 'neodentech'...
Thanks
Offline pete_flex
« Reply #1476 on: December 13, 2019, 11:41:29 am »
Does anyone have NeoDen's stated part placement accuracy? is it around 80 microns?
I have the X/Y positioning as 5 microns just don't see a placement figure. thanks
Offline GerardG
  • Pick and Place support manager
    • electronicatools.com
« Reply #1477 on: December 16, 2019, 08:36:47 am »
Hello Pete_flex,
Positioning resolution is not exactly what you need.
XY-repeatability +/-0,02mm
We place 0402 with the machine during demonstration. And show the result under the microscope.
0201 is also possible when fine tuning the placement and pickup height.
Regards,
Gerard
Offline cschew
  • Country: my
« Reply #1478 on: January 17, 2020, 07:21:37 am »
Need advice to solve the below problem:
Neoden 4 shown Attention message: Photography failed! try again.
Thank you
CS Chew
Offline luiHS
« Reply #1479 on: February 05, 2020, 12:21:32 am »
Thank you
CS Chew
I am having the same problem, and that is a failure of the camera or the cable that connects to the camera. I am waiting for a camera replacement to be sent to me from China on the 9th.
The complicated thing is to access the camera to replace it, you have to remove all the feeders on that side, and move the rail that hides 3 screws.
« Last Edit: February 05, 2020, 09:21:12 pm by luiHS »
Offline GerardG
« Reply #1480 on: February 05, 2020, 08:13:51 am »
Hello LuiHS,
We have spare parts stock for N4 ,IN6 and S1 in the Netherlands.
If under warranty we could have sent it to you.
Offline luiHS
« Reply #1481 on: February 05, 2020, 11:24:03 am »
Hello LuiHS,
Hello.
Yes, my Neoden4 is under warranty.
How can I get the camera and the cable?
Can you provide complete instructions or a video where I see exactly how to replace the camera? The document I have does not show it in detail, it only reaches the step of removing the 3 screws from the photo.
regards
Offline tboicey
« Reply #1482 on: February 05, 2020, 06:20:52 pm »
Posting this here, hope it is allowed.
There is a Neoden 4 for sale here in Ottawa, Canada. I know the seller and have seen the machine. Basically new.
No financial interest, etc. etc. Just pointing this out in case somebody wants a machine that is already in North America.
https://www.kijiji.ca/v-other-business-industrial/ottawa/new-neoden4-pick-and-place-machine-smt-for-sale/1478950574
(Price is in Canadian Dollars)
Offline jdrexler
  • Country: cz
« Reply #1483 on: May 08, 2020, 11:23:35 am »
Hi guys,
do you have please someone experience, how to solve following vision problem?
We have problem with vision recognition of following chip (image attached). We also tried increase light, but still Neoden doesn't see this type of smd parts..
Others are working fine.. Do you know, how can we fix it?
Thank you
Offline MR
  • Country: tw
« Reply #1484 on: May 09, 2020, 11:18:36 pm »
I don't have a neoden but...
How about cleaning the dirty nozzle and adjusting the camera settings (contrast, brightness) contrast up / brightness down.
You need to remove all the dust from the picture for the optical recognition...
« Last Edit: May 09, 2020, 11:21:12 pm by MR »
The following users thanked this post: jdrexler
Offline nisma
« Reply #1485 on: May 10, 2020, 11:43:31 am »
I suppose the Problem is the inner circle from nozzle. The intensity is similar as the component. Four additional TH LEDs at the correct angle should resolve the problem. For that component just one single led is probably enough but four for not influencing negatively other component recognitions.
Offline jdrexler
  • Country: cz
« Reply #1486 on: May 10, 2020, 05:55:33 pm »
Hello,
thank you for help. Additional side LED light solve it and vision recognized it correctly. We will try develop some extra light for this type of components.
Thank you,
Jan
Offline itdontgo
    • IoT Manufacturer
« Reply #1487 on: May 17, 2020, 12:02:29 pm »
We had this. The positioning of the cable meant that it would hit something every time it started up. Eventually, it cut through some of the conductors inside it.
I asked them for a replacement then realised what a massive pain it would be to swap it as it's connected to an internal USB. They said you could just plug it in to an external USB on the machine but instead I just soldered the broken wires back together and relocated the cable. It's never been any trouble since.
There was another annoying problem where the end stop photo sensor was misaligned and the x-axis used to crash into the end.
These two problem spoilt was is otherwise a really good and reliable little machine. Since I fixed them it's been great.
Offline tony-tid
  • Country: bg
« Reply #1488 on: July 07, 2020, 08:31:27 am »
Hello guys,
Can someone send me the latest update for NeoDen4?
I have some issues and I hope this update to fix them.
Offline GerardG
« Reply #1489 on: July 08, 2020, 02:21:47 pm »
Hello @tony-tid
What problem do you have and what is your current software version?
Offline tony-tid
  • Country: bg
« Reply #1490 on: July 09, 2020, 07:35:31 am »
Hello GerardG
My current version is the oldest one: 4.1.2 B3 ( the machine came with that version )
I have some problems from long time ago but still can't fix them.
1. It's hard to set the Fid. points.
- when I set the fid points, the head is moved close to them( thats ok not really big problem ),but sometimes not "see" them, so choose other more circular point.
- when the FIDs are set ( by hand or automaticaly ) the head pick the element but place it in coordinates for the machine, not the PCB.
ex 1 When the machine head goes close to the fid : the head is moved close to the fid points I choose them by hand ( cuz I use header vias ), the head pick the element and place it to this coordinates but not in the PCB area - in the machine area.
ex 2 When the machine head doesnt go close to the fid: The head goes somewhere around the machine area, so I move it to the fid points. Everything else is perfect.
2. The nozzle don't pick the element, but goes to the PCB and do the "place" move.
3. Sometimes while PNP, start to initialize the XY coordinates.
Offline GerardG
« Reply #1491 on: July 10, 2020, 06:47:15 am »
Hello Tony,
Looks like a coordinate problem.
You have a stable software version. I will PM you on this.
Best regards,
Gerard
Offline luiHS
« Reply #1492 on: July 20, 2020, 03:21:03 pm »
Hi.
I am having trouble with the cameras. It started with intermittent failures in one of the cameras, turning the machine on and off again worked for a while and randomly failed again.
Yesterday the thing was worse, because when starting the machine it gave a new error, and this time the two cameras failed. This message is given when starting Windows XP, and although it continues, the error is no longer resolved by turning the machine off and on.
The camera that was initially failing has already been replaced, so it seems that it is not a problem of the cameras, I think it may be a problem of corrupted software drivers or hardware failure of the motherboard.
Neoden gives me instructions to reinstall the camera drivers, first by running the KYSYSProtectApp program, and then reinstalling drivers.
Has anyone else had these problems, were they reinstalled by reinstalling the drivers or is it a hardware problem and requires replacing the motherboard?
Regards
Offline GerardG
« Reply #1493 on: July 21, 2020, 07:23:52 am »
Hello @luiHS,
I had the same problem on another machine.
Reinstalling the driver did the trick.
Also when placing the new camera, you need to guide the cable along the same path it has been before.
Offline atarasii
  • Country: ru
« Reply #1494 on: August 04, 2020, 08:23:36 am »
The function "Angle correction of up-looking camera" is not included in the user manual. What is it for? How to use it?
Offline GerardG
« Reply #1495 on: August 04, 2020, 09:56:05 am »
The uplooking camera, on the right of the machine, always has a very small rotation.
When all components seem to have the same rotation, then you can change this value to compensate.
As it is set in the factory you would never need to correct it, only when you change something to the camera.
Offline atarasii
  • Country: ru
« Reply #1496 on: August 04, 2020, 05:39:38 pm »
You write about setting - Upward photograph angle. There are no questions about her.
I am interested in the bottom line - Angle correction of up-looking camera. What is this parameter for?
1040722-0
Offline GerardG
« Reply #1497 on: August 05, 2020, 01:00:03 pm »
The bottom line is a tool to determine the angle that can be filled in the top field.
Offline luiHS
« Reply #1498 on: August 11, 2020, 09:22:02 am »
Hi.
Could someone tell me a utility to generate the files with Altium?
I found these two utilities, one with Python and one in Java, but neither of them works, both give errors.
https://github.com/michaelmoskie/Neoden4-Altium
https://github.com/Mishcatt/Neoden4-Altium-CSV-Converter
Regards
Offline GerardG
« Reply #1499 on: August 11, 2020, 02:16:09 pm »
Hello luiHS,
I have a video about it.
Will PM you.
