Placing a 4n7 - 70% in front of the switcher you mentioned isn't doing anything except creating high Q circuits which resonate with every bit of stray inductance around.
Thanks, thats an intereting statement.
So placing some small ceramic cap "in tight" to the power switching loop. so as to reduce the area of the power switching current loop...is a bad thing?
Its very common to do it...often you see it in the form of an SMD ceramic in parallel to the leads of a radial electrolytic cap......again, its there to reduce the current loop area.
But yes , i agree, there is going to be resonance with the stray L.
So , this would raise interesting questions...
1....in 4n7 is too low a value, what value would be OK?
2....Is the concept of putting a small capacitor "In tight" to the power switching current loop of an SMPS, always a lame duck?.....obviously, being a small package, means it can advantageously be squeezed in nice and tight to the power switching current loop....thereby reducing the loop area.
