Author Topic: MSL parts storage and care for the hobbyist/small business  (Read 8208 times)
Offline bob808
Re: MSL parts storage and care for the hobbyist/small business
« Reply #25 on: February 07, 2020, 06:03:25 pm »
Got some 3535 ws2812 (or compatible). Tested about 15 and they all were bad.
After reading this thread I decided to try and remove the moisture from them.
I baked one kg of table salt and I put it with the leds in some tupperware. How long should I leave them for? I'm planning in diy-ing an electric oven sometime in the near future.
There should be enough desiccant for the amount of moisture they could have stored in them, just that I have no idea how long should I leave them for. Would a couple of days do?
Online Siwastaja
« Reply #26 on: February 08, 2020, 07:14:03 am »
No, don't use desiccant to remove moisture from the components, especially not something corrosive like table salt. Most desiccants are likely not good enough to suck enough moisture out at room temperature, or it will take forever.
Just bake the parts using standard baking procedures (see Google). Using high enough temperature drives the moisture out in sensible time. The idea is to use lower-than-reflow temperature so that the parts won't crack from water evaporating too quickly; but high enough temperature so that the water is eventually (in a hour or two) forced out, through the plastic.
The following users thanked this post: bob808
Online asmi
« Reply #27 on: February 08, 2020, 01:37:01 pm »
I think a standard baking procedure is 4 hrs at 125° C and parts needs to be used within 30 minutes after baking.
Offline bob808
« Reply #28 on: February 08, 2020, 02:19:17 pm »
Oh damn, so I need to make an oven after all.  Need to source a solid state relay locally.
Then I'll remove the leds from the salt. Thank you for the heads up!
A temperature controlled oven would also allow me to dry my 3d printer filament. Think a 30-35l oven would do. My gas oven is not easy to control. 30 minutes is not enough as I wand to solder the leds on a keyboard. 68 leds, and I must solder them by hand as the rest of the pcb is already populated on both sides.
« Last Edit: February 08, 2020, 02:25:57 pm by bob808 »
Offline SMTech
« Reply #29 on: February 08, 2020, 02:26:40 pm »
If they really are that damp, I would suggest you're looking at  a much longer bake than a few hours but at a lower temp. After that store them in one of those vacuum tubs you can get for food,  with a desiccant pouch which you may also want to bake first.
Online wraper
  • Country: lv
« Reply #30 on: February 08, 2020, 02:38:42 pm »
Regular electric kitchen oven should do the job. Just check temperature with thermocouple or set temperature on lower side to account for possible inaccuracy.
Offline bob808
« Reply #31 on: February 08, 2020, 03:29:19 pm »
I'll try to measure my gas oven and see where it sits at min.
I should do that electric oven as it's really useful. I kept having the need for one once in a while but it never warranted to make one. But all bets are off if I can't get rgb on my keyboard  :scared:
Offline jmelson
« Reply #32 on: February 08, 2020, 06:22:27 pm »
Nope, burning natural gas produces water!  (Hydrogen plus Oxygen = water)  So, you really want an electric oven, even a little toaster oven set to
run at 50 - 70 C will bake out your parts.  Some tapes are REALLY sensitive to the heat, so that may limit your ability to bake parts that are still in the tape.
Jon
Offline bob808
« Reply #33 on: February 09, 2020, 04:46:00 pm »
I got them out of the tape.
I'm curious if I can do it with a sandwich maker  :-DD
SSR comes in tomorrow and I wanna test this. Should be fun.
Offline DavidMenting
    • Nut & Bolt interaction design
« Reply #34 on: February 14, 2020, 10:24:02 am »
I really wish that reputable companies like TI & Osram would team up to make a decent quality LED with internal control. Even if several times the cost of WS2812s, it would still be cheaper than the current solution I have to use on any permanent installation of seperate LEDs and drivers.
It's not Osram, but LiteOn does have a new line of LEDs with embedded control: https://optoelectronics.liteon.com/en-global/Led/LED-Component/Index/1/211#cate1
Regarding the SK6812: we've gone through dozens of reels of SK6812mini from the I-wouldn't-call-sketchy supplier @funbags mentioned. The failure rate of these LEDs is not particularly high. Definitely better than the failure rates I see mentioned on WS2812 LEDs.
The following users thanked this post: Kean
