Author Topic: Molex DuraClick Nozzle  (Read 1161 times)
Offline EmanuelTopic starter
« on: May 26, 2024, 11:02:28 am »
I am using a range of Molex DuraClick connectors on my PCBs.
I have no problem with the horizontal version, the machines are picking and placing them perfectly.
The thing is I can't see how to do the same with the vertical version.
They are supplied in reels but without any pickup tab as Molex uses on other series.
There are no instructions or recommendations anywhere.
Any ideas?
Offline loki42
Re: Molex DuraClick Nozzle
« Reply #1 on: May 26, 2024, 02:18:35 pm »
I'd pick up along that flat edge with a rectangular blade nozzle.  You might also need gripper nozzles if your machine can use those.  I'm looking into one for an annoying connector at the moment.
