Author Topic: PSR-4000 H85 (Locked)  (Read 3661 times)
Offline csjTopic starter
« on: January 23, 2014, 07:53:49 pm »
Who knows, where to find technical datasheets on the solder mask PSR-4000 H85 CA-40 H85 TAIYO?
« Last Edit: January 27, 2014, 07:24:09 am by csj »
Offline kizzap
Re: PSR-4000 H85
« Reply #1 on: January 24, 2014, 01:01:29 am »
If this isn't what you are after, try here
If you still struggle, then this is your best option. I would recommend trying to talk to either Pete Binzel or Steve Campisi.
Next time, use google?
<MatCat> The thing with aircraft is murphy loves to hang out with them
<Baljem> hey, you're the one who apparently pronounces FPGA 'fuhpugger'
Re: PSR-4000 H85
« Reply #2 on: January 24, 2014, 06:42:28 am »
http://www.taiyoamerica.com/index.php/products/products-pcbs
The list of products that the mask is missing.
http://www.taiyoamerica.com/index.php/contacts/sales-technical-service
Pete Binzel, Steve Campisi not responding.
This is the wrong answer to the question.
You do not know the exact answer.
Google search I well know how to use.
In Google there is no information even on the official site.
Forum in order and there is a person to get the correct answer.
Sorry for the translation - I could hardly speak English.
Re: PSR-4000 H85
« Reply #3 on: January 27, 2014, 07:23:09 am »
Locked.
Datasheets found.
Offline zapta
Re: PSR-4000 H85 (Locked)
« Reply #4 on: April 20, 2014, 07:02:51 am »
Locked? Let's see if this message will go through...
