Author Topic: Self-Laminating Two FPC halves?  (Read 2724 times)
Offline envisionelecTopic starter
« on: May 08, 2014, 01:45:45 pm »
I have a research project wherein I need to place an array of components between two layers of flexible PCB (FPCB). The components, which are piezo ceramics, will be glued with a Henkel conductive epoxy (TBD, but likely an Eccobond). What is involved in the laminating process on a DIY scale for proof of concept? I obviously don't want to crush the ceramics. I think I might have painted myself into a corner... :clap:
It seems I would need a custom plate to avoid crushing my components - or very careful ironing.  Anyone have experience with such a thing?
Offline scientist
  • User banned.
Re: Self-Laminating Two FPC halves?
« Reply #1 on: May 08, 2014, 03:10:36 pm »
Why bother with flex PCBs if you're going to laminate the halves together? It's not going to be rigid, and it's not going to be anywhere near as flexible as a single board.
« Reply #2 on: May 08, 2014, 04:55:31 pm »
If you are going to laminate you will need a press as large as the complete board, and with a platen top and bottom lined with a soft silicone rubber and with some PTFE sheet ( or other non stick plastic that your particular epoxy will not bond to) to apply a firm pressure while the epoxy cures. You assemble the components and align within the work time and then carefully press together.
« Reply #3 on: May 08, 2014, 05:13:53 pm »
Thank you. I have a press for doing LCD flex and anisotropic epoxy. This assembly is larger, but not by much. I have decided that the custom platen is the way to go.
« Reply #4 on: May 08, 2014, 05:14:30 pm »
The application demands an FPCB.
