Author Topic: Cheaper way to make a Rigid-Flex board?  (Read 1497 times)
Offline Gabe_from_OndaTopic starter
« on: May 22, 2023, 04:56:02 pm »
I'm looking to make a PCB that pretty much has to include a flexible PCB section or connect to separate flexible PCBs. It's still in the R&D stage but I'm only expecting to sell ~50 of the product per year, so there's not a lot of economies of scale even once it hits the market. The section that's going to have surface mount components is only ~10mm x 25mm. The flexible section only needs to have a 2" bend radius.
Would it end poorly if I just ordered a flexible PCB with a 0.8mm rigid backing on the SMT area and removed the cover film from that entire area? It would save a bit of cash, but I'm worried it would end up breaking. The other options I see would be to put FPC connectors on a rigid board and connect separate FPC boards, or to just shill out the cash for a properly made rigid-flex PCB.
Offline langwadt
Re: Cheaper way to make a Rigid-Flex board?
« Reply #1 on: May 22, 2023, 07:08:44 pm »
you can get solderable flat flex
Offline stone
  • Country: hk
« Reply #2 on: August 05, 2023, 04:53:18 am »
1.You can use this rigid-flex design.
2.use this welding method
