Hello,
can you me help to create a PCB Array. in the manual is this false. I have the smt550.
i will make 2 PCB in X (next to each other). in the software comes always "cannot Edit" when i will GEN PCB.
what are the instructions?
first from the first pcb to a fiducial and than the second pcb to the same fiducial?and than generate?
this has no function. always "cannot edit"
when i make on the plate a IC is this not a problem. but the fuction to make a pcb array is very difficult.
Regards
Stefan
