Author Topic: User friendly interconnects between proto-boards?  (Read 782 times)
Offline e100Topic starter
« on: August 05, 2024, 08:45:43 am »
I'm building a bunch of modules on individual 70 x 90mm 0.1 inch proto-boards that need to connect to each other and survive being disconnected and reconnected several times a day as I tinker with each one. The number of conductors varies between 3 and 10 depending on the board.
Regular IDC cables aren't really designed for this type of usage and I have doubts about the reliability of ribbon cables that are subject to repeated handling.
Screw terminals are slow and damage the conductor. Individual 2mm plugs and sockets take forever to solder.
Is there something better out there for doing this specific kind of job that will work with a standard 0.1 inch proto board?
« Last Edit: August 05, 2024, 08:47:51 am by e100 »
Offline SMTech
Re: User friendly interconnects between proto-boards?
« Reply #1 on: August 05, 2024, 09:55:17 am »
I don't see the issue with ribbon if you sensibly use connectors with cable restraining clips and treat everything with due care and attention. That said do you need the cable at all, can you not use IDC male/female and forgo the cable between?
Offline nali
« Reply #2 on: August 05, 2024, 10:07:27 am »
You can get ribbon cable headers with ejector lugs if you're worried about pulling on the cable
Or maybe pluggable terminal blocks?
I used to use Molex KK when messing with perfboard, they're pretty easy to crimp and remove or change wires.
Online Doctorandus_P
« Reply #3 on: August 05, 2024, 10:58:02 am »
I had a look at a few datasheets of ribbon cable IDC connectors. Some go as low as 30 mating cycles. In a datasheet from Wurth, three "performance" levels are mentioned with 50, 250 and 500 mating cycles.
A datasheet from 3M also suggested such a short number of cycles, but the pdf was ill formatted and it was unclear what the info actually meant. See page 4 on:
https://multimedia.3m.com/mws/media/787866O/3mtm-idc-ribbon-cable-socket-891-series.pdf
But what this all means?
The manufacturer is pretty sure your connector will survive this amount of cycles. It does not mean that it would fail a few cycles lager. or even 10x or 100x cycles later.
The stress relief brackets over the cable help to reduce stress in the IDC connection to the wires.The ejector lugs on the male sockets also reduce stress on the cables.
If you want robust connectors that survive a high amount of mating cycles, they become expensive really quickly. IDC cables with their plugs are easily replaceable if / when they wear out, but for the sockets soldered into a PCB it's not so easy. Oxidation probably is not a big issue, as the constant wiping will probably remove it. But it also wears out the (gold?) plating. A trick that is sometimes used is to use extension connectors. This way, you can disconnect an extension connector from a PCB and put a new one in if it wears out.
Maybe using USB-C connectors is an option. Apparently these are rated for 10.000 mating cycles but that probably does not hold true if you buy the cheapest you can find.
Offline ledtester
« Reply #4 on: August 05, 2024, 12:25:38 pm »
Maybe "pluggable terminal blocks", eg:
https://www.aliexpress.us/item/3256804030840641.html
They consist of two pieces -- a screw terminal block and a board receptacle that accepts the terminal block.
The following users thanked this post: the Chris
« Reply #5 on: August 05, 2024, 01:15:40 pm »
Good idea.
Good point, USB-C breakout boards are readily available.
I also found breakout boards for HDMI "type A" connectors which are basically a double sized USB connector which means they also have double the contact spacing of 1mm vs the 0.5mm found in USB-C.
FPC ribbon cables and breakout boards also look interesting.
« Reply #6 on: August 05, 2024, 01:43:26 pm »
The picture definiely shows 2.54 as the spacing. I've never seen them that small, however Sparkfun also has them, so they must be OK. The screw heads must be tiny.
Online tggzzz
« Reply #7 on: August 05, 2024, 01:55:26 pm »
Plus, with care, the connectors and cables ought to have reasonable impedance characteristics. While that's not necessary for audio, it is beneficial for modern digital signals and general RF signals.
« Reply #8 on: August 05, 2024, 02:41:48 pm »
Indeed things were looking good until I watched this video where they tested a bunch of HDMI cables and 16% failed either because of missing conductors or signal integrity, or both. Luckily all my signals are sub MHz but missing conductors is something I'll have to check for.
Offline Smokey
  • Not An Expert
« Reply #9 on: August 05, 2024, 04:00:59 pm »
D-Subs.  Love me some D-Subs.
Solder cup or crimp.  Either way.
Online tszaboo
« Reply #10 on: August 05, 2024, 04:38:47 pm »
Yes it's not like after 30 cycles it just stops conducting. I had this in production. There was this connector rated maybe 30 cycles, so I made it replaceable on the testing equipment. Made a few connectors, put it on the shelf ready to replace the production tester, then promptly forgot about it. The production people run thousands of boards through it and it was still working. I had to sweep out metal shaving and dust out it and it was still doing it's job good enough to test the DUT.
Offline janoc
« Reply #11 on: August 05, 2024, 04:50:33 pm »
Please, don't do this. At least not with USB. Using USB connectors for anything but USB is an invitation for disaster. Sooner or later someone will plug something in that connector that expects a standard USB device or a charger. If your device isn't USB, doesn't use USB voltage levels, doesn't have the usual pinout, then you can have an expensive mess on your hands.
HDMI has the same problem but there it is possibly less likely to cause issues because people associate those only with monitors and TVs and won't be as much tempted to connect their computer output to some random board having it. However, USB is everywhere these days.
It is the same reason why using mains plugs and sockets for anything else but mains is a terrible idea. Sooner or later someone will have a brainfart. It could be even you.
« Last Edit: August 05, 2024, 05:29:29 pm by janoc »
The following users thanked this post: Kean, Ian.M, tooki
Offline tooki
« Reply #12 on: August 05, 2024, 04:55:24 pm »
Ummm, IDC by definition is a way to terminate cables, so a PCB connector can’t be IDC without cable.
Do you just mean box headers?
Offline NightMoth
  • Country: cn
« Reply #13 on: August 05, 2024, 10:59:18 pm »
Hello
You can use JST XH2.54 cable and socket  or JST XH2.54 cable and pin header instead of socket (with pin header instead of socket you dont need to take care about cable header orientation).
I used 2...6 wire JST XH connectors for my project with bunch of protoboards which i was assemble/disassemble many times for tuning, and it was easy
https://www.digikey.com/en/product-highlight/j/jst/xh-series-connectors
« Last Edit: August 05, 2024, 11:14:37 pm by NightMoth »
Offline ledtester
« Reply #14 on: Yesterday at 12:00:37 am »
You could also go with 5.08mm spacing to fit protoboards... although sometimes they have thicker pins which would require enlarging the holes.
« Reply #15 on: Yesterday at 01:42:52 am »
Hello
Now I'm confused. Is JST XH2.54 an actual size?
The JST web site lists XH as the 2.50mm series and RE as the 2.54mm series.
https://www.jst.com/products/crimp-style-connectors-wire-to-board-type/xh-connector/
Online sellers are listing XH2.54 connectors so they are either using the genuine JST RE series or else using copies of the XH series with a custom size.
Offline NightMoth
  • Country: cn
« Reply #16 on: Yesterday at 02:40:09 am »
Hello
Yes, you are right, it looks like original JST XH series is 2.5mm, but it looks like almost all wendors name similar 2.54mm connector as "JST XH" as well.
I'm using "JST XH" with 2.54mm size for 0.1 inch perfboard, and i checked its size in product's specifications on wendor's web store before ordering
« Last Edit: Yesterday at 02:46:39 am by NightMoth »
Offline tooki
« Reply #17 on: Yesterday at 07:26:22 pm »
In my experience, the cheap Chinese vendors call it “XH2.54”, but actually ship 2.50mm, which makes sense since they are supposed to mate with real XH.
Of course, 2.54 and 2.50mm pitch are so close that for up to about 10 pins, you can fit XH into a 2.54mm PCB footprint or protoboard. The exact number depends on the hole sizes.
So don’t take the fact that they fit 2- and 3-pin XH clones into your standard 2.54mm protoboard as any kind of evidence that you have actual 2.54mm connectors. I doubt any XH clones with an actual pin pitch of 2.54mm exist.
I’ll also point out that genuine XH are so inexpensive that I don’t bother with the clones anymore. (Except for the wire-mount male version, which JST itself does not manufacture!)
« Last Edit: Yesterday at 07:29:37 pm by tooki »
The following users thanked this post: shabaz
Offline kripton2035
« Reply #18 on: Yesterday at 09:13:41 pm »
molex micro-fit can be good candidates too.
« Reply #19 on: Today at 02:04:50 am »
Those have a 3mm pitch.  :(
« Last Edit: Today at 02:15:38 am by e100 »
« Reply #20 on: Today at 02:15:07 am »
I found one vendor selling XH2.54 who provided an engineering drawing showing the pitch as 2.50mm.
My first thought was that they had linked to the wrong picture but now I realise they are simply selling 2.50mm connectors under the 2.54 label.
« Last Edit: Today at 02:18:45 am by e100 »
Offline NightMoth
  • Country: cn
« Reply #21 on: Today at 06:09:45 am »
Maybe you are right, I failed to measure my "JST XH2.54" with calliper perfectly, but it looks like indeed it closer to 2.5mm than to 2.54mm... anyway difference between 2.5mm and 2.54mm for 10 pins will be negligible.
On attached pictures I compared 5pin "JST XH2.54" with 30x 2.54mm pin-header array and distance between pins looks very same. 30x2.54mm pin array fits into 0.1inch perfboard, so 10-pin "JST XH2.54" will fit perfboard without any problem as well.
Offline kripton2035
« Reply #22 on: Today at 06:53:37 am »
yes, but easily bend into a perfboard even for a 6 pins connector.
