Does "Review Parts Placement" work correctly?
I just circuit for forehead, and at the time of final viewing the components is not in the correct position, but if I remove two components, the position is almost correct. (Attachment Link)
My first 4 boards were fine in the Review Parts page.
My 5th board (uploaded Thursday/Friday) just wouldnt display properly.
Tried many things while waiting for support to get back to me (expecting a response on Monday)
Just now, i tried editing the x,y positions of the first item in the placement file. Changed the numbers thou even though i knew it was meant to be in mm
Everything displayed except the first item.
Next, i moved that item to the middle of the file (with the correct x,y numbers in mm) and everything displayed fine.
Made no sense to me so generated the files again and left the first item where it was in the placement file and it still displayed properly.
I can only conclude that something was fixed on their end while i was testing the files again.
I'm using a Perl script to convert the placement file from Proteus to the required BOM and CPL files so i cant see what manual error i could have made when trying previously. So, try again, it might work now.
Some other people also had problems
https://easyeda.com/forum/topic/SMT-Assembly-Wrong-components-placement-a8d4fb943cf340eeb9309faca7340b23
