Their library is a huge mess. They don't even have a link for it on their main page anymore.
They also added like 2000 components as "basic" that are not in stock. And the same ICs are in 3 different categories.
Power Supply Chip/Linear Voltage Regulators (LDO)
Power Management ICs/ Low Dropout Regulators(LDO)
Power Management (PMIC)/ Voltage Regulators - Linear, Low Drop Out (LDO) Regulators
Like FFS fix the database, it takes 5 minutes to write an SQL query or whatever database you are using that will place these into one category.
First, let me say, AMEN. Their library is such a mess. I have part numbers that I can find with a direct search but try to find it going through their indexes - no luck. I am certain they have parts that are close to impossible to find.
They try to provide a search interface similar to Digi or Mouser but their data is a complete mess. For example, selecting a given pin pitch will find maybe half the entries with that pitch because they didn't get the data entered. And, the web interface frequently wedges so I have to start over.
But I don't think fixing their SQL will solve anything - their data needs to get fixed first. They should first start with fixing their categories. Looking for an optocoupler? Is it in:
- Optocoupler
- Optocoupler/LED/Digital Tube/Photoelectric Device
- Optocouplers & LEDs & Infrared
- Optoelectronics
- Optoisolators
The answer is all of the above and the groups are only partially overlapping. Compare that with Mouser, it's night and day. One heading and clean categories.
