Welcome to the forum!
It looks like you've designed a watch to solve a very specific problem (or set of problems). Unfortunately that means the market for this would also be very specific, and therefore quite small. That makes it a lot harder to recoup the cost of putting it into production, and your watch looks like a fully-custom job with unusual features (like NFC and touch buttons on the display), which would require a lot of development work. Just to get a useful sample, you'd need to do most of the design and development work required for series production, and no reasonable OEM is going to do all of that work for a sample unless you're willing to pay for all of it up front (and possibly not even then without a volume purchase commitment). I don't want to be too much of a downer here, but I'm not surprised you haven't gotten anywhere with the OEMs you've talked to. They're probably looking for customers who want a customized case, or maybe a slightly different LCD layout, and what you're asking them for is orders of magnitude more work for something that will sell in uncertain volume.
Your desired functionality honestly looks like a better candidate for a smart watch app rather than a dedicated hardware device. That's something you could probably do yourself -- it will be a very slow start if you don't already have experience with app development or writing software in general, but certainly doable and the only hard cost would be a smartwatch to develop on, if you don't already have one.
Alternatively, you could try to develop a hardware device yourself, but that will be harder -- you'd still need to write the firmware for it, and possibly a phone app too, plus all of the challenges of designing and building the electronics (making them efficient enough for battery life isn't exactly trivial, not to mention the size) and the housing (making it durable and waterproof, if that's desired, is also not trivial). Getting the custom LCD made would still be somewhat expensive (you will still need to commit to buying at least a few hundred, probably), but not as bad as a whole custom watch. On the whole it's certainly doable, but will be a ton of work, especially if you want something you can sell as a consumer device.
